I was victim of an attempted carjacking. And those young punks wearing masks and gloves shot 4 bullets in my face and in the car. Lost the left eye but the car suffered more than I.
I just want to get it fixed so that…Anyway s a personal challenge i think.
the windshield the steering knuckle I heard is pushed back there’s something grinding every sharp turn I make it’s idling loud in park, I needed the brakes done .
the headlights might need the harness or socket replaced cuz no bulbs light up. And one tire rim is crooked it’s a may-pop😭😂
I have a spare but no bolts for it .
i bought a spindle knuckle from eBay and replaced the brakefluid reservoir that had a bullet hole in it . Gosh what else
Still runs and i needed a jump start 5 times in the last month . Idk if it’s cuz I hadn’t drove it for a while or the cold or the bullets . My Bluetooth cassette is stuck inside the player .
i almost paid 6000 for it last year it had 86k now it’s got 97k.
What can I do where do I start ? Anyone got parts for sale ? Thanks
1999 w210 4matic wagon, 2014 w166 4matic ML350
sorry to hear of the violence. hope you're recovering well.
my wagon has 340k miles. currently sitting at mechanics, awaiting rear suspension hydraulic lines. Mercedes still doesn't use copper/nickel lines, they use mild steel, and it's a car killing problem. fuel, brake, and rear suspension self leveling systems all end up with rusty lines.
between the wheel and suspension parts you mentioned, I would also look at ball joints and steering components. if it's a 4matic, front axles are very reasonably priced. on a 100k mile car they might not have been replaced yet. to do the axles basically all the front suspension and brakes get pulled, so it's a great time to do brakes, balljoints, steering stuff, and struts if you're close. Chrysler used the same parts on a bunch of cars so parts prices are reasonable.
the headlight harness has inaccessible connectors behind the front bumper cap, they go intermittent and cause problems. my independent had a sedan with the front end taken apart, I asked him about it. it was a customer who had bought all the parts to convert from hid to halogen, mechanic disassembled to do the job and instead found the connector issue.
Got a new battery , replaced the windshield, tie rods, front brakes without bleeding the systems nor rotors. 2 used tires with the oem rims. And got the Bluetooth cassette out the deck. I installed the battery myself I think I might need to tighten it. . Still idling rough.I’m going to check the MAF today. And the check engine code 0136 I hear it’s not that important. A lot of expenses sometimes cash. It’s too bad the dealers couldn’t help it’s driver more.
rough running 3.2l in both our cars (the other is a 2004 211 e320) was coil packs and spark plugs. I bought new spark plugs and used <<75kmiles coil packs/wires off ebay, fixed the rough idle and performance issues.
Discussion Starter · #5 ·
That would be tuning up or buying another one!!! I was wondering if there’s such thing as a total accurate diagnosis of everything that needs to be fixed. i paid way too much for the inspection I’m yet to tackle!!!
i tested the maf sensor myself it seems to be bad but then the other codes0100 and 0110 reappeared I had previously taped the 3 inch crack in the first segment of the air intake manifold. Before the incident it didn’t idle that rough. It almost sound like I’m pedal to the floor when i shift to park.
Now someone told me to get the transmission checked out as heheard the squeaking sound when I was backing out.
I guess I’ll try a better
oBD and see what the dealers say!!!
