1999 E300TD: 365,000 kms.Parked for the winter. 2002 Golf TDI, 426,000kms, winter beater
Hi everyone,
This is the first time I am starting a new topic, so if I posted in the wrong place, wrong way , or didn't find the topic covered elsewhere etc......sorry in advance.
1999 E300, OM606.962, 230,000 kms (144,000 miles), stock condition except EGR delete with resistor as per someone on the internet.
PROBLEM -- occasionally misses at idle (every 5 to 10 seconds, once or twice, just enough to slightly shake the engine), only when warm, only if no load (Park or neutral, A/C off). Car starts runs drives great other than that, lotsa power, no unusual noises, smoke etc, fuel consumption as always (33 to 36 mpg).
The car will only do this when it is completely warm, at no other time (yet...). Any load on the engine (in gear or A/C on), and it stops.
Also, when I step on the accelerator just enough to raise the idle speed a few hundred RPM (normal idle anytime 600RPM), it will accelerate smoothly, may miss when running steady, will definetly miss several times while slowing back down to idle RPM (again, in Park or Neutral, no A/C). -- The car will not do this unless operating warm.
There has been no work done to the car in the last 4 months of driving, and this started about 3 weeks ago.
I did the fuel screen (tank), pre and main filter today, no change, also took all 6 injectors out, had them spray pattern and pop tested -- perfect, no change in behaviour.
List of things that have been done in the past
--injectors cleaned and tested last year
--all clear fuel lines and seals replaced last year (no, I do not have any air bubbles when the car runs -- trust me, I carefully looked)
-- glow plugs last year, when I did those I did look down at the inlet valves and air inlets, I do not apparently have any symptoms of inlet valve seat recession, I also checked again about 4 months ago when I replaced the starter.
My delivery valves are not leaking, the injector pump timing has not changed according to the slip mark from when I had it checked two years ago (required no adjustment).
Could this be a bad delivery valve? Anyone know the symptons or had one go bad? I have read in a few places that a bad copper crush washer could cause this. This is my next step, replace delivery valve seals, copper crush seals and delivery valve springs.
I have also read that a bad MAF sensor can cause all kinds of strange problems....mine does not have a code, or any codes whatsoever at this moment (I suspect if it gets worse the computer with the help of the CPS should be able to give a specific cylinder code....????). I am trying to get my hands on a friends used and defective MAF, his idled smoothly, but he got a code, and no boost.
My next step is to try and isolate the cylinder in a few days, either by loosening one injector line at a time, or, removing intake manifold and very lightly spraying a small amount of ether into one cylinder at a time, see which one stops the problem.
I have done an Italian tuneup, no change there either.
Anyone any ideas???? I am not lost or at the end of the line by a long shot, just wandering if anyone has had this before, and can help out, so I can save myself a bunch of time, which I am always short on....
Cheers and thanks in advance.
