I have a w204 c250 with OEM 17" staggered wheels (staggered in the sense that only the rim width of front and rear wheels are different).
The sport also has a slightly lower front suspension.
Even still, the 245/45/17 tires fit fine all around with no rubbing.
There is a slightly noticeable sidewall bulge on the front (due to the narrower rims in the front that are 17"x7.5" vs 17"x8.5" in the back).
I like it as it fits the wheel wells better, and I got them for cheap and it works. Where I am, I need the extra clearance to avoid scrapes and obstacles.
OEM 225/45/17 front-- 25.0" tall
OEM 245/40/17 back-- 24.7" tall
245/45/17 are 25.7" tall
If I were to do it again (and eventually will when these long-life 540 utqg tires wear out), I would go with 235/50/17 in front (26.25" tall) and 255/45/17 (26.0") in back to make the look more uniform (sidewall bulge), wider rear tire look, get another 1/4" clearance in front, and fit the wheel well tighter (I am almost certain this will work for me when I checked clearance to suspension components (upper control arm) and fender well liner, etc, but I personally have not tried them yet, so beware for fitment issues). It is just a lot harder to find those tire sizes that are not super expensive, don't wear out fast, and a matching set/brand. The fronts are easy to find but the 255/45/17 are about 50% more in price and have short tread life as they are more race-oriented. I am not a fan of buying new tires every 18 months.
