Hi, I'm new to this forum and desperate for guidance on getting rid of the gremlins that are plaguing my C200 estate (2 litre petrol, automatic).
I realise that the only way to help identify the problem/s is to fully describe what is happening so I will post a comprehensive description of what I believe are at least two different electrical problems.
From what I have researched to date it is clear that I can spend a small fortune replacing various parts and sensors on a scattergun approach with no guarantee of success so I really hope someone here has experienced the same issues.
The first problem is one I have read about before; -
From cold start up, the engine starts and runs ok but then misfires (badly) after a few hundred yards - this is only cured by switching engine off & restarting - this may be repeated two or three times during first 2miles but will then run ok...
I'm aware that the misfire is just the engine management shutting down (probably 2) cylinders but I don't know why???
My best guess so far is maybe "Cat" problems causing bad exhaust gas reading or a faulty sensor giving a duff reading? - but once warm, the problem goes away!
The second problem is more serious because it can happen suddenly and everything electrical just dies and the engine runs at barely idle speed (seriously not the best thing when you're in the outside lane of the A3 doing 60+mph)
This sequence of "malfunctions" can happen at speed (i.e.on the A3!!) or it can happen when the vehicle is parked up & simply ticking over at idle.
Basically I get a fairly quick succession of "malfunction" messages:
I can't recall the exact order in which they appear but they are; -
Battery/alternator - visit workshop
Then ABS, ESP, SRS
Display reads 6 malfunctions
And no electrics work at all (incl. dashboard elements - speedo, rev counter, the indicators, the lights etc)
But the engine still runs (on idle) but won't rev much beyond tick-over
Next, I switch the engine off..
Switch ignition on again - and dash now reads "no malfunction" (no idea why it removes all the malfunction messages?)
The LIM light is illuminated on dash, as is low fuel (amber) light - despite gauge reading full! Also warning triangle, ABS, brake & BAS/ESP lights.
Red SRS light also comes on but goes out after a short while.
Unlike the 1st problem, this time I try to restart - and nothing! (Starter initially 'clunks' but doesn't turn).
After approx 10mins the car finally restarted!
Ran approx 1mile then fault codes all came back up... Went into limp mode, all electrics failed - engine running at idling speed & lumpy/kangaroos when attempting to drive it (in limp mode) -
So I pulled over and waited..... left it idling and after 2mins engine started to hunt - it was revving between (approx)800 & 1200 rpm on it's own accord (as if I was blipping the throttle twice a second) Then it stopped doing it after about 3minutes (as if it were running some kind of self testing / diagnostic.)
During this time the auto-gearbox wouldn't engage at all (i.e. locked in "park")
The display added a new message - "display defective - visit workshop"
THEN - after maybe 10mins? the engine revs freely again.... Gearbox engages but BAS/ESP light almost immediately came on and ESP switch appears disabled but all other electrics come back & car runs ok - no restriction on engine speed - revs up to red-line and even the gearbox kick-down works.
I have considered the following potential problems but I'm not convinced they are relevant, just a by-product but I could be wrong..
Many of the issues are symptomatic of a flat battery - but as soon as faults clear the lights etc work without any apparent sign of low power?
I've checked battery voltage and it's looking ok.
I've not checked the alternator output but I'm not experiencing any flat battery symptoms on these cold mornings so I can't imagine that the alternator is dodgy (but maybe I'm getting intermittent fault codes / readings from a faulty sensor or wiring fault?)
Also symptomatic of loose starter lead but again, as soon as fault clears car starts & runs fine so I don't think this is it either?
On another thread several members have advised that faulty brake light switches can cause ABS/ESP faults as can bad sensors and poor wheel alignment - I'll get my tracking checked this week as I need a pair of tyres anyway...
Probably not connected but I have also had bulb failure messages - I've noticed that headlight (n/s) works & then fails & comes back again on a random basis. Other lights all work when checked but then randomly drop out - e.g brake lights. but when I check the bulbs they're ok!
I'm hoping that my car isn't fit for the scrap heap.... for all it's gremlins, it's a lovely clean car and it's not a high miler....
Please help!!
2005 C230 Kompressor
Problem 1:
I had similar symptoms; cylender 3 would misfire intermittently when i punched the gas pedal, and the system would shut it of until I restarted the engine. I had a dealer look at it, they replaced coil #3 about three months ago, and I have not had the problem since.
Problem 2:
My Mustang was acting up like that, the battery light would come on, then idle would drop, and sometimes the engine would stall. A repair shop "fixed" it three times; two control modules, an alternator, several sections of wires replaced, and a few thousand dollars, the entire electrical system shut-down on me a few days later. It stalled out in front of a dealer, so I took it as a sign, as soon as it started back up, I pulled in and traded it for my C230.
you have to get the codes read to see if there are any stored codes. the check engine codes are totally separate from the dash display. a bad voltage regulator (part of the alternator) can also cause all kinds of weird electrical gremlins. on most benzes it can be separately replaced and it isn't expensive.
