Hi all. my w203 exterior door handle is quite tight and hard. i am trying to remove it to install a new one. The torx screw hidden in the door is stripped and only spins, not allowing me to tighten or loosen. Any ideas on how i could remove the torx and therefore my handle? Thanks
68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
If the bolt has a head, sears makes a set that you basically pound over the outside diameter and it then grabs the bolt. If that doesnt work, then just drill it out since you are replacing the handle. While in the lubricate everything!
