Hello!
I upgraded my c280 fog/driving lamps to LEDs. “Plug and play” from the Car Lighting District. When the ignition is on lights work fine. When the engine is running they flash (6 seconds off 1 second on). Code on dash tells me the bulbs need to be replaced.
Thoughts?
2005 CLK320
Hello!
Thoughts?
The current these draw is most likely just on the edge of allowed tolerance. When you start the car the voltage goes up and and current goes up and causes the error message and blinking.
This can be programed what is the year of your c230?
Sent from my SAMSUNG-SM-G870A using Tapatalk
Thanks for your quick response. It’s a 2007 C280 4matic
