1997 w202 c180 facelift
I have done project about w202 multifunction steering wheel .
There are three important thing we need
1. Multifunction steering wheel from facelifted w210/w208
2. Instrument cluster with monitor facelifted w210/w208
3 steering wheel clock spring with 5 pin connector from facelifted w210/w208
Hood Collar Eyewear Automotive lighting Font
Then we can start working on it , we need t30 and 10mm wrench and some tube for grip because it's hard to unscrew bolts.
Two t30 bolts behind the airbag and one 10mm bolt in center when you remove airbag
There is wiring connection
Rectangle Slope Font Parallel Number
Speedometer Car Vehicle Motor vehicle Gauge
There are 2 brown wire for horn circuit .
1 brown wire on ground (anywere on car chassis)
2 brown wire in N1 conector on second plug
Hand Green Finger Gadget Thumb
Discussion Starter · #2 ·
Car Vehicle Motor vehicle Speedometer Automotive lighting
Car Vehicle Speedometer Odometer Trip computer
Radio volume control didn't work because it needs multifunction steering wheel adapter which connects to m1 and m2 conector and other ends to stereo
