1 - 12 of 12 Posts
02/1997 W202 C280
my c280 doesnt have DRLs and i was wondering if i bought a switch for a c280 that had DRLs if it would work with my car that doesnt have DRLs. and if not is there a way to make it work? the cheapest switch on ebay that i found is $40 and its for a DRL car, the switch for a non-DRL car is $118
W163 and General M Gremlin
Are you sure the DRL is in the switch?
I dont believe swapping the switch will solve the problem.
In our 99 c230K, under the DS dash, next to steering column.
The silver tin box is what provided DRL.
Screen Shot 2020-07-22 at 11.32.30 AM.png Screen Shot 2020-07-22 at 11.32.37 AM.png Screen Shot 2020-07-22 at 11.32.55 AM.png
02/1997 W202 C280
View attachment 2643376 View attachment 2643377 View attachment 2643378
Im not looking to add DRLs to my car i was just wondering if i replaced my current, worn out headlight switch with one from ebay that is for a w202 with DRLs if it would work normally or not.
My bad.
Yes, if you have DRLs already, swapping the headlight switch should be fine.
So it wouldn鈥檛 work on a car without DRLs?
I havent seen the ebay ads you are referring to and why one is almost 3Xs the price of the other.
So I dont know what you are referring to in relation to these switches you are watching on ebay.
I presume the ebay listings have a part# associate with them?
Ive swapped plenty of switches for w202s and they are all independant of the DRL system installed (silver tin box)
(at least up here). For the w202, the silver box was an "add-on" to comply with required DRL in other countries.
I dont believe the US had DRL requirements.
For the w210s, the headlight switch itself had the DRL features built-in to them so if owners wanted to delete the DRL function (as I did on our w210), you needed to swap a US version headlight switch (same switch just no DRL wiring inside)
02/1997 W202 C280
I messaged one of the sellers on eBay , the seller鈥檚 name was skyur, the other day asking if the switch they were selling would work and they said that the switch for my vehicle would be $113 from Mercedes since it was the incorrect switch.
I haven鈥檛 seen a non-drl switch on eBay, all I鈥檝e seen was the DRL switch.
Is there an extra connection on the DRL switch compared to the Non-DRL switch?
Not that I am aware of.
What's your vin#.
I can check the part # against others (including mine) to see if there is anything different.
Sorry for the late response,
WDBHA28E0VF575889
No worries.
Your part #20
A 000 545 62 04
On our w202, same part #
Perhaps the seller with the higher priced part either believes this part is special or he's just a snake salesman.
02/1997 W202 C280
Discussion Starter #11
He ran my vin# thru the "Mercedes dealer parts database" which explains why its higher than the one he has posted because it an aftermarket part.
2643501
And with that knowledge in mind I'll know what to look for. When I looked at the part he was selling about a week ago it was ~$30 and now its $40.
I've used both oem and non-oem for this part# up here, depending on what was provided for me to install. Both work fine. A quick look on fleabay, there are less expensive ones.
1 - 12 of 12 Posts
