1998 W202 C200
About to undertake the replacement of the bushes.
Could someone please send me a copy of the WIS manual showing the orientation and instructions to replace the front suspension bushes. I see they are not symmetrical so need to be pressed in the correct orientation.
The old ones fell apart!!
Thank you
Paul
W163 and General M Gremlin
Thank you
Paul
Community Search, at the top of the page.
keywords ====> w202 lower control arm DIY
All the info is there in the search results.
Please read before posting to familiarize yourself with this forum:
If you could do all the potential readers a favor,
Please complete your BW registration profile
so members may better assist you, seeing and knowing what you drive.
Goto your ===> user CP profile====> click on your icon (top right corner of the webpage) ----> then click on "Account Settings"----> goto Account Details----> add vehicle details---->
ADD your make model YEAR (i.e. 01 ml320) into your Profile ----> (MUST) click save at the bottom of that page.
YOUR vehicle info will then show/display under your username & avatar (on the left side) once it is completed. If it doesn't display under your Avatar, it wasn't saved.
Members will then see your avatar car info & know what you drive if replying.
1998 W202 C200
Trust me - I have spent most of Saturday looking for information on the orientation of the bushes and can find only conflicting data from home mechanics. That is why I requested from the Mercedes WIS - I think they should have definitive information.
1999 C230 Kompressor
I've done this job and if I had to do it again, I would rather replace the entire control arms in 1 piece. You really have to have a strong industrial grade hydraulic press to remove them and press the new ones in.
Sorry, I don't have the WIS but I was able to see how the old ones were oriented and pressed the new ones in that same way.
1998 W202 C200
Discussion Starter · #5 ·
Thanks for the advice.
I asked the spares shop to show me the complete arm with bushes to find the correct orientation.
I have replaced the front bushes. Not so bad - hacksawed the old ones out and then used a 14mm threaded rod and various sized washers and spacers to press the new one in. I think maybe freezing the bush and heating the arm will make it even easier. Will try that when i do the back ones
Biggest problem were the springs - my spring compressors are the cheap ones. Cannot recommend those. Had one shoot across the driveway! No damage or injuries luckily.
Now I need to inspect the rear ones.
Nice, glad to hear. Usually the rear ones don't wear as fast as the front ones. And yes, I recommend the mercedes spring compressors where there are 2 plates on the top and bottom and one threaded rod that goes through the middle.
