2007 w211 220 cdi Avantgarde
C-class 220D 1995, It all started wth a leak from the diesel injection pump only when the engine was cold, and then one day while driving engine revs droped to idle, pushed the pedal down but nothing, turned the engine off and on again and it was back to normal but this was short lived cause it hapened again 10 minutes later and it has been like this eversince, so i took it in for a dignostic test and it came up that the THROTTLE POSITIONING SENDER is faulty, went to the stealer and told me it costs £650 plus vat. Looked on e bay but can`t find it second hand, part number A00954288817 and then i am not sure that replacing this part could be the solution to the problem knowing that the LUCAS diesel pump is also leaking. ANY OPINIONS ?????????
'96 C220 n/a diesel
When mine came on it was the fuel filter needing changed, its 1 of the symptoms of 2 much water in the filter. Didnt help the tank was near empty tho, i filled it rite up n kicked the ass out it after the filter change and it cleared mate
