1 - 1 of 1 Posts
To get at a broken seat latch, removal of the back seat panel seems possible means of access.
Does anyone know how the panel is attached to the seat. I would assume it is attached using inserts into the metal of the seat - the same as how door cover panels are attached
A gentle applying of a metal separation tool may be used?. .
If so, are there any tricky sections that need removal first. Note the seat is firmly held in the upright locked position so I would assume only the top of the seat panel can be separated from the seat proper and prized open. Once open a means of removing the latch assembly may be determined.
1 - 1 of 1 Posts
