w166 ML350BT EGR and ADblue delete, went te clogged DPF
1 reading
9.4K views 9 replies 3 participants last post by  ubrak
Hello, i need some good advices.
2 months ago i remaped my 350BT. The remap included, more power, adblue delete and EGR closed. But now, 5000km later, the car i loosing power and smoking. High backpreasure and high booster preasure. The DPF is clogged, most likely by removing adblue.
So... As i can see, i have two options..
1. open up exhaust, and permanently remove the dpf, and code the dpf away.
2. Go back to orginal software, and try to open dpf by force regeneration from the star machine. And then, leave the car orginal.
What do you mean??
Regards
#8 ·
Okey, thanks for reply;) Your case is a bit different. When deleting adblue from ecu (like i did), dpf will stop regerating. A broken nox sensor, may stop adblue, but not stop the dpf`s regen process. Do you get any erros Messages in instrumet cluster by the broken nox sensor?
#9 ·
Just the usual Check Engine light. I just ignore the check engine light at this time, there is no emissions testing here in Texas for diesels. I may eventually either crawl under the vehicle and replace the NOX sensor or pay someone to do the DEF, EGR Delete and eventually do the DPF delete as well. I tried a last week to replace the NOX sensor but was not successful due to the heat shield being in the way. I may attempt the replacement again in the near future.
