2001 E320; 2002 ML500
How is it possible that the unibody W164 has a towing rating of 7200 lbs and the truck based W163 only 5000 lbs? This does not make sense to me..........
2001 ML430
I believe the W163 had a towing rating of 7000+ in Europe. Maybe lawyers got involved here in the states?
Does the W164 have beefier brakes? Bigger coolers on the transmission/engine?
I dont know, just throwing stuff out.
03 ML350
Better hitch. US 163 should have had a conventional style receiver hitch that mounted to the frame rails. European 163 hitch is a different design that brings the load point closer to the crossmember and hence reduces the moment load. The 164 uses a hitch design that couples the loads to the vehicle better.
2002 BMW M3 Coupe, 2002 Mercedes Benz ML320
Maybe I'm off-base, but I wouldn't even consider towing anything close to the maximum recommended weight (5000 to 7000 lbs). If you're looking for a towing vehicle, get a truck.
