W163 ML500 ignition switch / no start fixed!
1 reading
5.6K views 1 reply 1 participant last post by  RichDiesel
#1 · (Edited)
I bought an 05 ML500 in kind of a shady deal. It had a "Start Error" which would not allow it to start. I spent a lot of time digging into it with the majick computer (clone Xentry/DAS), and managed to clear the Start Error message on the dash. I'm not sure what all I did, I was digging into it and cleared a lot of codes, paired the remote fob, did other stuff, and finally after doing various things with the computer the code cleared. So that was a success. Was not apparently the keys and code chips as those all checked out OK, the DAS (Drive Authorization System, a little loop antenna around the key switch that reads the chip in the keys) appeared to be happy. I had pulled a DAS loop and module from a junker for cheap, they are like $175 new, did not need to use it.
Still would not start, after doing some research it was suggested that the starter power K8 relay in the fuse box under the hood was either bad or it was not getting power to make it work. Swapped out relays (there are a bunch that are the same), still no workies. Turns out after doing some electrical diagnosis I discovered I could jumper the relay contacts to get the engine to turn over and start with the key in Run position 2 all dash lights come on. (YAY!!!!). I put a momentary contact switch on the jumper wires so I could cover the fuse/relay box, lift the hood and just push the switch to turn over the engine to start. (I tried to run it into the cabin but couldn't find a convenient hole).
So that suggested that an electrical switch behind the key lock switch, that the key lock actually actuates to start the car, was bad in the start position 3 -- positions 1 and 2 worked and I could start and drive the vehicle in position 2. There is a way to test the switch and wires right there at the switch (pink wire I think, marked #15?) but it is tight in there so I didn't bother with that aspect, in any case that wire is what goes to the relay activator contacts (these are the contacts in back of the relay slot that are along the axis of the car, the actual starter actuator contacts are the front ones that are transverse) and I was getting no power to activate the relay.
Common issue on these vehicles apparently, can make you crazy, a new part is like $25 so I ordered one the other day.
There are 3 covers to take off around the back of the steering wheel and the various arms behind it. There are 3 Torx T25 screws on the bottom one, some plastic tabs on the top one, and some tabs and metal snap connectors on the right panel. They mostly pop out with release of the tabs and a bit of gyration and having the wheel tilt up or down. I POSTED SOME MORE PICS IN THE COMMENT BELOW
The DAS ring that reads the key chip is the box on top, it will just push off to the back of the housing, just move it back out of the way. The electrical switch is at 90deg to the key switch in a round housing. They are (fairly) easy to pull once you get the covers off. Small hands would help but I managed to get the connector off (there are locking tabs with little arms you can squeeze with your fingers, although I used a screwdriver to push the front lock tab you can see and managed to squeeze the back one and the connector popped right off. Note that there are some tabs on the top of the connector that slide into the back of the lock and in the housing so it will only orient one way, pretty much with the tabs on the top at 12 oclock if you could look from the back.
I HIT MY LIMIT ON PICS IN THIS POST SO WILL PUT THE REST BELOW IN A COMMENT*
The actual switch is further inside the round housing, and there are also 2 locking tabs that hold it in. You can feel inside the round housing and get the tabs released, although again you can use a screwdriver on the one if front. I could not get a good grip on it to pull it out so got a small pair of pliers to grab a contact tab and pull it right out.
There is a small tab on the back of the key switch that turns the ignition switch, it is like 1/4" wide it looks like, you can see on the new one how it will fit over the key switch tab. The old one was clearly chewed up a bit and it was hard to turn with a screwdriver even if the slot was OK (which it wasn't) so that was the problem, the switch wore out or bound up and would not turn to position 3 to start the engine.
SEE IN COMMENT BELOW
The new one slid in OK once I got the tabs oriented to the slot in the housing, as with the connector, although I did have to put the key in a move it a bit before the new switch would slide over it but that was easy enough.
Buttoned everything back up, took out my jumper switch, popped the relay back in, and JOY!!!! Engine started right up. YAY ME!!!! I did notice too that the key turned more easily so the switch was definitely buggered from that indication as well.
This time it took like an hour, next time would be like 20min.
Here are some more pics of the trim pieces, 1) remove right side piece with a pry instrument, some metal snaps and a plastic tab or two, 2) top piece, there are tabs at the back on either side and some on the bottom toward the wheel, push those in with a screwdriver or similar, 3) 3 T25 screws on the bottom one and it drops off. That top one will need to move around a bit to clear the stalks, drop the wheel down lowest.
The electrical switch is at 90deg to the key switch in a round housing. They are (fairly) easy to pull once you get the covers off. Small hands would help but I managed to get the connector off (there are locking tabs with little arms you can squeeze with your fingers), although I used a screwdriver to push the front lock tab you can see and managed to squeeze the back one and the connector popped right off. Note that there are some tabs on the top of the connector that slide into the back of the lock and in the housing so it will only orient one way, pretty much with the tabs on the top at 12 oclock if you could look from the back.
The actual switch is further inside the round housing, and there are also 2 locking tabs that hold it in. You can feel inside the round housing and get the tabs released, although again you can use a screwdriver on the one if front. I could not get a good grip on it to pull it out once I released the tabs so got a small pair of pliers to grab a contact tab and pull it right out.
