My truck is stuck in low range (low range light is on). It drives like a bus and won't shift. Occasionally, the low range light turns off by itself when cruising for ~3 seconds and it can shift again, only to turn back on right after.
These are my codes:
ETC
041:
"[One or more messages from control unit N78 (Transfer case control module) are intermittently not available on the CAN bus or the transfer case position is position is intermittently implausible.] or [One or more messages from control unit N78(Transfer case control module) are not available on the CAN bus or the transfer case position is implausible.]
DTC Status: Resistance too low"
137:
"One or more messages from control unit N78 (Transfer case control module) are intermittently not available on the CAN bus.
DTC Status: Resistance too high"
AAM
B1040-003:
"CAN BUS: communication control: N78(distributor drive control module)
DTC Status: Stored"
I have tried clearing the codes, but they still remain. "Low Range" Light is on 99% of the time. I read somewhere that I must replace the transfer case motor (as they are prone to fail). Is this correct? If so, is there an updated transfer case motor (where they corrected this flaw and what is the part number)? Should I get a genuine MB part or an aftermarket like Dorman? When installed, do I have to clear the codes again or is there just gonna be no "low range" light?
Thanks in advance.
These are my codes:
ETC
041:
137:
AAM
B1040-003:
DTC Status: Stored"
Thanks in advance.
