ML 320 W163 1999
Its hard to tell the condition as they are so dirty. I agree with what your saying but would like slightly larger than my 17" wheels but not going over the top. I believe these are stock rims off a w164 they shouldn't be too bad with higher profile tyres.
2002 BMW M3 Coupe, 2002 Mercedes Benz ML320
Hi!
was thinking of getting some slightly bigger wheels on my w163 nothing over the top and came across this on ebay
19 inch Alloy Wheels 5 spoke 5x112 with spacers ( mercedes part no A1644011402) | eBay
Quite local but wondering if it will be worth it as the tyres will all need changing for 255/50/19 i believe?
Changing rims on an ML is primarily cosmetic. Whether it's "worth it" is subjective. It's your money! I would tend to avoid a rim that required a spacer, but if you like the look of those rims, you may have no choice but to use them. You should check the offset of the rims.
1998 ML320
And don't forget to look at the cost of the tires for this upgrade. I found a couple of sets of 19 alloys for cheap, then priced out the rubber. That bit is definitely not. Put it this way set of 4 AMG alloys for $250, then each tire was $1200.
'05 ML350
OEM wheels -- chromed
Hi!
Those look like OEM ML wheels (newer model) that have been chromed. Previous owner had them on a Galaxy, hence the spacers, but you won't need them for your ML. You will however need longer lugs.
