W163 ('02+) Roof Antenna Replacement / Fix DIY
9799 Views 57 Replies 14 Participants Last post by  BokkieAndijk
I completed the Roof Antenna Shroud & Seal repair for my 2003 ML350 (w163). This is a complete tutorial on each step.
New online item ordered:
Uro Parts brand Roof Antenna Repair Kit:
2649623
Tools used:
-Trim Pry-Tool (Red Handle)
-Trim Wedge (Orange Plastic)
-Torx S2 T9 size driver
-18mm Wrench
Optional:
-Gloves
-Soft bristle brush to clean
-Cleaning wipes
-Upholstery Cleaner
-Needle Nose Pliers
-Small Power Drill
-Blu
2649622
Interior work area:
Rear Storage Compartment (liftgate open):
1. Headliner Trim cover piece removal
2649625
Used Trim Pry-tool (Red Handle)
2649626
2. Headliner panel retention-clip removal
2649627
2649629
2649630
3. Removal of Antenna Assembly-body retention nut:
2649631
Used 18mm Wrench
2649632
Note: Nut needs approximately 10-12 rotations to release from Antenna Assembly-body.
See less
Tools used:
-18mm Wrench
Optional:
-Gloves
-Cleaning wipes
-Upholstery Cleaner
-Needle Nose...
See more
10
1 - 20 of 58 Posts
· W163 and General M Gremlin
Welcome Denver_Del,
Nice start with your 1st post.
===>>> Please update your user CP info....
click on your icon----> click on Account Settings---->
goto Account Details----> add vehicle details---->
ADD your make model YEAR ----> click save
Reactions: Denver_Del
Mercedes-Benz 2003 ML 350 (W163)
Exterior: Removal of old broken Antenna Assembly-body from roof mount location:
1. Lift up to remove:
2649634
2649635
2. Clean dirty area.
2649636
2649637
3. Remove all of old Seal from Antenna Assembly-body
2649638
4. Use Torx S2 T9 driver to remove old retention screws
2649639
2649640
5. Clean off all old Seal material gunk
2649641
Note: Inspect and clean board and Antenna for serviceability and to make-ready for installation of new Shroud & Seal
Discussion Starter · #4 · (Edited)
Interior: Rear Storage Compartment Area:
1. Re-install of Antenna Assembly-body retention-nut to threaded Assembly-body bolt
2649652
2649663
Note: Ensure that the (3) Antenna/GPS signal & electrical wires are seated in the gap-are of the Retention-nut before starting to tighten it securely back to the threaded
2. Tighten Retention-nut completely and inspect roof area to make sure no open space is left and the assembly is not still loose
Sensitive content, not recommended for those under 18
Show Content
2649656
2649657
Interior:
1. Re-install Trim panel Headliner Retention-plug
2649658
2649659
2. Re-install Headliner Trim panel cover
2649660
2649661
Note: Ensure that the weatherstrip is seated properly & snugly using Trim wedge tool
2649662
3. Install Complete !!
Good Luck, I hope this helps you be successful with your repair!
2649664
1998 Franken-ML, 2002 ML55
I think you could have made replies to yourself in the first post to get around that, but either way works.
I wish they sold that seal by itself. The full kit isn't cheap, and it doesn't seem to be in stock most places. My housing is fine, but the seal is a bit dried out.
2003 ML500 w163
Just bought same 2003 with 5.0L so ML500. 2 days later a few drops of water dripped down on rubber cargo mat under antenna. Bought some neoprene sheets $15 super cheap on Amazon. Arrives in 1 day.
Will pull off antenna tomorrow and re-seat on top of a sheet and cut around it to create perfect seal.
FM radio gets no reception. Perhaps the water damaged something. AM works fine. Nav disc is missing so can't even test that. Black spot on LCD.
May swap whole radio eventually.
Thanks for the step by step!
That's not the radio antenna.
2003 ML500 w163
Well. It's done. Here are the pics and comments. Hope it helps others.
Seems someone changed the stub antenna to sharkfin style. It leaked.
Brick Metal Flooring Tile Floor
I removed plastic and unscrewed retaining nut.
Vehicle door Vehicle Auto part Automotive exterior Car
Wire Glass
Someone put black caulk in the past. Had to clean the roof down to the paint.
Material property
Fit the antenna over the 3/16 neoprene sheet. Need thick because sharkfin is flat and doesn't match curvature of roof.
Automotive exterior Vehicle door Vehicle
The clip that was in there was plastic and homemade using a plastic white toilet seat bolt and nut. Crazy!
Photo shows I replaced with brass. But plastic wouldn't hold tight enough to seal.
Had to remove a 2nd time and create a bracket from aluminum. Where's my disc grinder and belt sander?
Metal
Automotive exterior Vehicle Roof Auto part Car
The metal was right enough to seat properly. Several rainy south Florida says and not a drop inside.
If the GPS receiver works is another matter. Nav won't load bc says DVD missing.
1999 ML430 and 2003 ML55
Clint....go with the new technology....the ML's are ripe for tasteful upgrades. I had a new Kenwood headhunt and subwoofer installed recently (along with a backup camera) and its really nice to have those features.
New speakers would be nice, but the factory BOSE sound pretty damn good !!
2000 E 320 Wagon + 2002 ML 500 SUV
Yeah 😊 and mine has the Bose system. Haven't heard them yet bc only get AM radio.
Does your Factory Bose headunit not have CD slot / Tape + CD Changer ?
That should do it....use mine everyday.
David
· Super Old Fart Moderator
2002 ML320, 2005 S430 4MATIC RIP, 2010 F150 Crew Cab
I repaired mine using a 3D printed unit from a former member here sgtpepper. I wished those were still for sale.
1 - 20 of 58 Posts
