1021 - 1040 of 1071 Posts
1999 CL500
To my knowledge, there were never coupe-specific wheels, factory or AMG.
Looks like you are looking for "flush" fit in the back - a spacer 6-8 mm thick will probably do it.
Make sure you get longer bolts.
Thanks and yes, sorry. What I meant was the wheel arches on the coupe look more flared to me than the sedan. So I thought my spacer requirements might be different to someone looking for spacers on a sedan.
I saw on page 36 someone put some spacers on their sedan and it looked nice.
I found a video on youtube explaining how to measure the edge of the wheel to the outer part of the wheel arch to decide on spacer size.
I will do this and order some and then post photos.
99 CL500.
Who has experience with wheel repair? Have a few different leads on some Monoblock wheels with a fair share of curb rash or clearcoat missing. Is there a point that wheel repair should just not be considered or the rims have gone beyond their service life?
Dies it even good work look like a patch job if metal work is involved?
Been seeing repair prices between 80-150/rim, so all that goes into my cost vs buying a set in better condition
1999 CL500
I have experience with getting rims repaired that are bent, and with very heavy curb rash (pieces of the edge missing) and have had very good results. They have come out looking like new, balanced perfectly and driven very well.
I would personally draw the line on rims that are cracked that require welding.
In my neck of the woods, 18" wheel refurbishing starts at $150-180/ea.
This does NOT include welding.
The monoblocks you are speaking off cut with a lip that is "diamond cut".
This will add to the cost a bit, if you want it.
Otherwise, the standard process is just strip, prime, paint + clear.
There are National companies that will send someone to pick them up from you and return in about 72 hours (google AWRS)
99 CL500.
For those with staggered 18” wheels, what tires are you running? Have you been happy with them regarding noise, ride quality and longevity
· Outstanding Contributor, Vintage Moderator
450slc5.0cab 280sl5sp 280se4.5 500seAMG +250seStkW108 350sl4spdX3 500secEuro 300sel5spd R+C107galore
I missed the wheel repair topics a month ago. The problem with cracks is that they require deep welds that end up making brittle spots in the rim. You weld one spot where a crack has been, and the weld is strong, but since the welded metal is so hard, you end up with cracks next to the weld next time you hit a bump. It would require top notch skills to make a good deep weld without causing this type of problem.
As for curbed lip repair, this is a cosmetic weld that can be done without heating the entire area of the wheel and build it up little by little instead of doing a deep hot weld.
That’s how I understand wheel welding can be done to add metal to curved lips, but cracks often result in garbage. I normally just sell the cracked wheels or wheel barrels or lips as cracked rather than paying $35/crack to get them welded. It would have to be something really rare to justify the welding IMO.
Lip repair is $90/wheel for me at my discounted prices for bringing so much business to my wheel shop.
Full wheel refurbishing is $135-170/wheel for me at my discounted prices, but when I’ve brought in 12 wheels at a time I have been able to get it done for $100/wheel. I pretty exclusively work with 16” wheels. Smaller ones can be cheaper and bigger ones can be more expensive. Sometimes it just depends on the condition, how bent they are, etc.
Sometimes wheel refurbishing includes the risk of determining that the wheel has a critical flaw and no wheel repair shop will touch it after they stripped tons of paint or even metal off and then return you a piece of scrap metal and say “sorry, but this one is junk.” That’s happened to me when I brought a set in for what I thought was a cosmetic refurb, resulting in me holding a “set” of 3 really rare wheels until I ultimately just sold it as singles. Lost a bunch on that one. Win some. Lose some.
99 CL500.
Bump from earlier....
Buying a staggered set of 18" A220 Monoblocks
2204010802 8.5 &
2204010902 9.5
Still looking for tire size and brand recommendations
1999 S320 SWB; 1991 300CE; 2006 MB diesel sprinter van
Can anyone tell me what lug bolts I need to replace my stock 16" wheels on my 1999 S320 with a set of AMG Monoblocks 1404010102 ET47 18X8.5" 5x112mm?
Thank you
99 CL500.
Thank you
Ditto, im about to have the same situation next week too, well not real W140 monoblocks, but w220, A2204010802
99 CL500.
Shopping for tires…
it seems like 255/45-18 is the correct optional size for the sedan all around, but searching on Discount tire and other places, I don’t see it as an original option for the Coupes up front. I’m finding the largest front tires suggested is 245/45-18. I know it’s close to original size, but not exactly the same
I have a stock height vehicle, 99 CL500, and want to get a square set of tires, just want to know if the 255s will fit up front without issue, or if I need to stick with 245. Also seeing Standard load is suggested as fine, was under the impression the higher rated sidewall load is preferred
Ignore them. Search by size. 255/45/R18, sedan or coupe, doesn't matter.
For the wheels you've got, this is the correct size.
If I were you, I'd just drive 2 hours north to South Bend, TireRack headquarters and will buy these Potenza's from them:
They will install for you while you wait (that was their practice years ago, not sure how COVID has changed the status quo)
1998 W140 S320 SWB
Looking to buy a winter wheel set for my 1998 W140 S320. The car came equipped from factory with 6-hole wheels on right. I'm interested in a set of 8-hole wheels on left for winter.
7.5 x 16, 5x112, ET51 . . . and I have ~14+mm stud holes
Does anyone know the proper part number for the wheel on left that meets my needs?
Wheel White Tire Rim Locking hubs
TIA
Matt
'92 W140 500 SEL
Is it possible to legally use the R19 Monoblock 2 on W140 S500 Coupe 93´ ??
Only R16 and R18 are in my vehicle registration document..
(R16 - 7,5 x 16 H2 LS; 235/60 ZR16)
(R18 - 8,5 x 18 H2 ET44 LS; 255/45 ZR18)
AMG and Brabus (and others) made 19 zoll rims for W140, and the laws in Germany are very strict about those things, so it should be legal in Czechia too. You could find an original prospect so you can prove your point.
First post....
Looking at buying these bad boys for my c140. They are 18x8.5 ET 44 with 255/45/18s. They are designed for the w220 s class. I am not too worried about clearance, rather that the bolts won't fit. I see a lot of posts of bolts being to large or small. Can anyone tell me how to find this out?
Wheel White Light Rim Material property
99 CL500.
Stock ride height all around. No issues with rubbing or clearance.
I went with a lug set off Ebay,
But quicker option would have been through Otis In LA
Did you see my other thread where i ran into the problems...
Got the 3 pieces back from powedercoating, assembled, and picked out tires.
They're starform Type D, 17x8/17x9, both et 24. I picked Michelin pilot sports A/S 3+, I didn't want tire quality to even be a question (plus the fronts had a load rating of 97, was pretty happy with that)
One last thing... 17's ride so much better than 19's... Sidewall cushion is a very underrated thing. Largest I would go in the future is an 18".
View attachment 2467750 View attachment 2467752
Sent from my SM-N950U using Tapatalk
I NEED MORE PICS of THAT BEAUTY
