141 - 160 of 190 Posts
MY97 S320
OK I just read through basically this whole thread, lots of info, but not specific areas where to look when buying. I have seen some M104 and M119 based cars up close now and want to add some to do with oil leak details, what to test and look for regarding the transmission, some cooling system checks and a few other things.
At the age these cars have reached if a car has not had fastidious maintenance there is likely to be oil leaking from more than one place. Under the car is likely to be covered in oily grime making oil leaks very hard to locate. IMHO in most cases sellers want to get rid of these cars due to one or more problems that need fixing, so you better be good at finding those problems!
So here goes, some pointers for inspecting the condition of a M104 or M119 based W140:
Both engines: check coolant when the car is cold, plan ahead requesting the car not be started before you arrive, hopefully the coolant is clean with no scum or anything under the filler cap or in the expansion tank. The color should be that of MB specified coolant not green glycol crap or old coolant faded to opaque dirty water.
While the car is still cold remove the aux belt and feel for looseness, rotate by hand and listen for noises on all the pulleys (PS pump, alternator, water pump, tensioners, everything) and tensioners. At this age there is bound to be a loose one or two or the water pump that feels rough when turning, even if it doesn't leak, bad bearing etc etc.
Test the AC and heater at full blast. AC should freeze your balls. Heater should feel like hell after not very long if the engine is at operating temp. Test operation of both sides at different temps to check duo valve operation. Leave the AC on full for a while to heat everything up. The engine fan has a viscous drive and this should engage before the AUX electric fans do, if not the viscous drive needs replacing. Make sure the AUX fans engage if the engine temp climbs above 110 or so. The temp gauge can move about from a faulty gauge in the cluster showing excessive engine temp.
After you have driven the car with the engine at operating temp check for leaks with engine off as the coolant system will be under pressure.
S280 & S320 M104 engine oil leaks to look for:
Engine cam cover gasket at the rear, oil can seep down then wick around to the exhaust side due to the angle of the engine. This might look like a head gasket leak but it is not.
Rear main seal is a common leak with a completely revised rear main seal available from Mercedes to fix. Front main seal does not have this issue but is much easier to check and fix if required.
Front "U" seal between upper and lower section of the cam chain cover, if engine has been ran with excessive oil the engine is more prone to leaks. Mercedes revised down the recommended oil level.
Right hand drive cars have an oil cooler located under the oil filter. The perimeter seal can perish and oil then leaks down the side of the engine above the starter motor.
(Side note: Interestingly the M104 series engines use a cast iron block and have piston squirters unlike the M119 and M120 that use an aluminum block with no piston squirters.)
S420 & S500 M119 engine oil leaks etc:
Oil leaks are not as prominent on the M119. Check the front main seal and the cam covers, you will need to remove the air intake assembly to have a good proper look.
Have a look at youtube videos showing the dreaded cam oiler ticking noise to familiarize yourself with this sound. This can sound quite bad in person but is far from an impossible problem to fix. If you come across a seller that has not disclosed this problem at least you will know what it is if you hear it, it's not the end of the world.
POWER STEERING pump seal at the front manifests as a slow leak, requiring removal and rebuilding. Steering box can leak quite a lot of oil requiring seals to be replaced, access to which is tight.
AUTOMATIC GEARBOX 722.3 and 733.4 mostly on pre 1997 models are hydraulic controlled with mechanical shift linkage mechanism with further vacuum control. Before starting check the oil, it should be low on the dipstick and a healthy red-orange colour. The level comes up with the transmission at operating temp. If the oil is in the darker burnt to greenish black colour it shows abuse of the gearbox or it is out of adjustment, and possibly very old oil and has absorbed moisture from many many years.
When engine is still cold the transmission will delay shifting to 3rd gear, this might seem abnormal but it is normal operation. Check for smooth shifts both up and down, test for healthy kickdown, test manual shifting at sensible speeds. If something doesn't feel right it could be a multitude of causes, ranging from a simple adjustment or vacuum leak up to possibly detrimental wear or failure of an internal component. If the shifter mechanism feels a bit loose it is just old tired shifter bushes, a very cheap fix but it could show the car has not been serviced by a mechanic with a brain.
At full throttle from a stop the car should change through the gears near redline, gear changes should still be smooth but no flailing, 0-100kph time should be close to advertised.
Test reverse, it should not take excessive time to engage and should drive the car with confidence just as the forward gears do. If you need to rev the car for it to move, if it feels weak and/or strange noises in reverse gear are symptoms of the common reverse lip seal and/or spring retainer failure.
There are a dozen or more seals transmission oil can leak from off the top of my head. Rear seal is the easiest to spot, and seals at the front at the input shaft are hardest to fix due to access requiring removal of the gearbox. If there is oil leaking at the front of the gearbox it could be the engine rear main seal, color of the oil should be a tell tale sign.
AUTOMATIC GEARBOX 722.6 is fitted to most or all later model cars. It is roughly a redesigned 722.4 box with an extra ratio added to the rear and a lockup torque converter up front. It is electronically controlled with a manual shifter for some operations. I do not have owner experience with this box but I understand the common problem leak with the main electronic connector at the front, and a rubber boot that can tear with use and age at the rear. Everything else is similar enough to the 722.3/4
Check operation as per the 722.3/722.4 box above, however this transmission does not have a dipstick and was marketed as "sealed for life", so it will be hard to check the oil when looking at the car and there is a greater chance the oil has never been changed since they put it in at the factory. :eek:
Re. any of the transmissions, if the car does not have a documented gearbox rebuild factor that into your purchase price if you plan to keep the car for any length of time.
Under the car check the two rubber flexdisks on the tailshaft for cracks. Small cracks are ok but the rubber should be structurally sound. A rumble vibration through the car while driving can be caused by flexjoins in need of replacement. Check boots around sway bar links as the boots on cheap non-genuine parts can crack very easily. Check the suspension bush condition, hopefully you can find a car with fresh bushes!
While driving if the steering wheel shakes it is either from out of balance wheels or out of round wheels/tires. Shaking while braking is warped brake rotors. There can be a slight shake at certain speeds from old suspension bushes but I have not experienced this, correctly balance and round wheels will expose this problem.
Check suspension for clunks and knocks, make sure steering isn't too floaty. Also make sure tires are at proper pressure around 36psi as this can be the difference between thinking the shocks and bushes are gone, to thinking the car rides ok.
Listen to the engine while idling for any noises, make sure the AC compressor and PS pump is very quiet or silent, give the car a bit of a rev but while stationary to listen to any noises but the EMS limits the engine to 4 or 5k rpm.
Final notes: Do not buy a W140/C140 as your only means of transport. Have a 2nd car (another W140 or C140?) as a backup for when it needs some love because she will.
That's all I am prepared to write tonight and I have not touched on the ignition and fuel systems and many other aspects of the car. This is my no means a step by step guide to an exhaustive inspection but if you don't know your way around a W140 the above tips might help a bit. The information is my opinion and I am not a mechanic.
Edit: If anything I typed is an obvious error please notify me and I will correct the post.
Hi, I just joined the forum today to research the likely sales proceeds I am able to get on the sale of my 1995 s500 coupe and since you seem to have significant experience, I thought I would reach out to you. It has 82,223 miles, 76,000 by my aunt. I would say it is in mint condition and drives like a dream. I would greatly appreciate your thoughts. I don't know how to upload pictures into a reply yet but I have a good portfolio. Thanks in advance for your thoughts.
· W140 Moderator
"CHRIS" Merc 92 600SEL / Sold > 93 600SE / 93 S500 / 89 560SEL / 413CDI / B180-CDI /A170-CDI
Discussion Starter · #143 ·
IF THIS WEBSITE GOES DOWN AT LEAST WE HAVE THIS ARTICLE HERE FOR US ,ORIGINAL LINK IS AT THE END OF THIS POST . :thumbsup:
Mercedes-Benz W140 S-Klasse Used Vehicle Review
Mercedes V140 (Long wheel base version)
The Mercedes S class is the pinnacle of luxury cars, it's the car you look at to find out what you may expect in ten years from lesser cars. The W140 is on the list because it's a car that is unique in the way it drives, rides and handles. Upon first inspection of the car you realize it's enormous, and you'd be right as it's the largest S Class Merc has ever made. It was designed to take on Rolls Royce at the time and needed to be large enough to fit the wealthy owner comfortably in the back. The second thing you may notice is it's not exactly good looking but it does have quite a presence, I'm willing to overlook the so-so looks because the interior and drive makes up for it. After I drove this car I quickly realized that at some point in my life I want to own an S-Class, maybe it will even be the first one!
As I mentioned above Mercedes always fills these cars with notable features making it innovative in some way. The big features of the W140 S class included double pane glass creating an insulated window which would help avoid condensation and filter our exterior noises, self closing doors and trunk which could pull themselves shut when gently latched, a rest function that would circulate heat for up to 20 minutes after the engine was shut down, up to four zone climate control on higher end models, 12 way electric seats, Parameter steering allowing easier maneuvering in parking lots by reducing input effort, and park distance control. A lot of these features are found on cars these days at much lower prices but in the 90s these features were unheard of, and very high tech.
W140 Interior
The interior of the W140 is first rate everywhere, lots of leather, wood and thick carpet, everything is well made and stands the test of time extremely well, it also includes all the goodies you would expect in a car today such as heated seats, automatic climate control, ability to set different zones for each person, high end Bose audio system etc. Unfortunately though the interior is where some issues crop up likely due to vehicle age. Things like power locks and windows may fail. Mercedes uses a compressed air/ vacuum system to actuate the locks so it has what is called a PSE pump (Pneumatic systems equipment pump) under the passenger rear seat with a little electric motor to create a vacuum or compression to actuate the locks unfortunately this little motor tends to fail over time due to years of service. It can be replaced though for under $10 making it a fairly cheap fix if you're willing to do it yourself. If you're not willing to do the job yourself a dealer will replace the entire pump costing a few hundred of your dollars. Other possible issues leading to failed locks include leaks in the vacuum lines, leaks in the tank itself (unlikely, but possible) or leaks in the connectors from the pump to the lines. Replacing the lines in the car could be tricky as they weave through the entire car but if you're willing to do the work you can save a fair bit of coin. A second PSE pump is also used for the gentle close doors and is located in the trunk it works in a similar manner as the one under the back seat and also has the tendency to fail with age, the same problems above are common culprits. It's important to check all electronics in the W140 you're looking at due to the number of electric goodies in these cars, it could be something as simple as a fuse but also could be the component itself that has bit the dust so before buying be sure they work.
Other common problems are also generally associated with age including rough idle or possible stalling which can be due to a mass airflow sensor, bad spark plugs, spark plug wires, or coil packs. This is not at all a problem with Mercedes quality though and will simply occur because these cars can be 20 years old now and with time these parts just wear out. Keep in mind it will be expensive if you take it to the dealer or a similarly trained Mercedes mechanic to have fixed. Performing these repairs yourself can be relatively inexpensive as parts aren't as expensive as you might think (coil packs are under $100 for example). Some of these jobs will not be for the faint of heart however as they require you to take a fair portion of the engine apart, if you're not the type of person who likes to open the hood and check things out you should budget for dealer trips when something goes wrong.
Vehicles costs apart from repair and maintenance aren't the cheapest due to the fact that most of these vehicles come equipped with V8 engines (more on the engines later) and require premium gas, and when I say require I don't mean you should put it in but can use regular - I mean you must use it to avoid replacing engine parts because it is known to foul up spark plugs and mass air flow chambers so budget for premium fuel when looking at these vehicles. Gas mileage it self is quite good considering the size and weight of this vehicle (some weigh close to 5000 pounds!). City mileage as you would expect does suffer but getting north of 25 MPG on the highway isn't a rare occurrence, some people admit to getting over 30 MPG while highway cruising. As true with any car your fuel mileage is more to do with your driving style than the vehicles itself.
On to the engines. In North America there were 4 engine choices for the W140 including a 3.2L inline six producing 228hp and 229 lb/ft, a 4.2L V8 producing 275hp and 295 lb/ft, a 5L V8 producing 315hp and 348 lb/ft, and finally a 6L V12 producing 389hp and 421 lb/ft. Out of these engines there are two I would avoid, the first being the inline 6 due to low power output coupled with a heavy car, and the V12 because it's known for many issues and is very costly to repair as well as being difficult to work on because the W140 was designed for V8s and it is crammed in the engine bay. The 4.2 and 5 make great choices both producing good power and delivering reasonable fuel economy.
After reading the last few paragraphs most of you are probably thinking there's a lot wrong with this car it just looks like a big expense. While it's not the cheapest car it does redeem itself in many regards, the main one is the drive. W140s drive extremely well, they have a planted fell which I've never experienced in anything else, yet they also soak up bumps while travelling on less than stellar roads (a common occurance in Ontario). The handling of the car is a bit surprising because you don't expect such a large car to go around corners very well yet this car somehow does, and it does so without getting upset or losing composure. The engine is smooth, well balanced and will pull strong from just 1000 RPM, a trait I love about Mercedes. The car even starts off in second gear when being driven normally to ensure the start from a stoplight is as smooth as can be, and will only drop into first when really prodded. It's a vehicle that likes to chug along at about 1300 RPM and will shift below 2000 making it almost silent. The brakes are very smooth and powerful despite being burdened with the weight of this beast. It's a car I feel that was built to be the best it could be, corners weren't cut in the name of cost savings and it shows when driving one, every control is silky smooth and operates beautifully, frankly I can't understand why you would buy this car only to sit in the back.
Posted 20th June 2012 by Joel Cummings
Opinionated Autos: Mercedes-Benz W140 S-Klasse Used Vehicle Review
1997 S500 Coupe & 1994 S500 Coupe (with ADS)
11k is a bit much, my family was able to acquire a pristine condition 1 owner 95 S500 for 6k with 60k miles on the clock, with all records, but that was a very lucky find. It was a white on tan color though. We don't like the color but it was just too good to pass. We got it by having connections to a dealership that had the car traded in for a new benz. The guy always calls us when he has a nice W140 worth looking at.
Try to bargain on the price. As for the years of the models I'm opinionated.
I personally love the build quality of the 93 above all other years made. If the 93 had a 722.6 transmission and an aftermarket or updated radio from the later models, it'd be the perfect car. I like the 97 more than the 95 because it's more updated with the transmission and safety like side airbags, but I don't like the 97 for it's interior/leather quality compared to previous generations. If all prices and mileage were even, I'd pick updated 93 > 97 > 95.
If you're happy with the car, then none of that matters. W140's were/are great masterpieces no matter the year. Each one has its quirks.
· W140 Moderator
Discussion Starter · #145 ·
Another great video from Ken ,it should be here .:thumbsup:
· W140 Moderator
Discussion Starter · #146 ·
· W140 Moderator
Discussion Starter · #147 ·
W221 / W140.
Mercedes Benz S-Class built today compared to the ones built in the pre 2000's (W140). - AutoSpies Auto News
Mercedes-Benz W140 on Car Magazine, Reviews, Ratings, News
Just a few of the quoted pots within ;
I believe not. My father owns the 1998 MB S600 and it runs great, never had a problem with it for like what?.. 15 years? And also he didn't do many check ups on the vehicle. No sensor problems or computer problems... You guys simply were unlucky with your W140. W140 are tanks, they are made to last and take hits. Unlike most cars now that use fiber glass and plastic for exterior, MB still used Metal for the exterior of the W140. Also the W140 M119 engines, were reinforced Metal to take hits during Head on Collisions. So the Point that you just made on 1990s MB using Plastic is wrong. The Other Models other than the W140 were made in plastic.
I think the new W221 are on par with the W140 with respect to engineering, design, as well as build. I have owned a 1995 S500, a 2007 S550 and currently a 2007 CL600. The S500 (140) had presence which the next generation S-class (W220 US MY 2000-2006) lacked (too effeminate and Jaguar-esque in design). My S500 had no electrical problems and its fit and finish were spot on. The W220, however, had too many joints, too packed yet-to-be-proven electronic aids, and not enough "king of the road" styling for a top model MB, which was later regained by the W221s. I think the W140 and W221 are natural S-classes for their respective eras.
w140 MADE S-class the Benchmark...FACT
· W140 Moderator
Discussion Starter · #148 · (Edited)
10 things to be aware of when test driving a used vehicle.
Buying a used car should be a straightforward transaction. But if you have little or no mechanical knowledge and are easily persuaded, the used car market can be infested with sharks eager to relieve you of your hard earned cash.
To help save you from unwanted pain, we have come up with a simple checklist to safeguard you against buying a lemon. Here is what to be aware of:
Know what you are looking for
Before you even think of going for a test drive, you need to have a sound idea of what you are in the market for. Start by setting a realistic budget, bearing in mind estimated running costs, like registration, insurance, fuel, servicing and repairs. Next, have a poke around online and create a
shortlist of cars that you feel suits your budget and needs. Research various online forums about each car in your short list and find a balance of good reviews for a car that fits your price guide. Once you’ve narrowed it down, it is time to have a closer look.
Leave your bias at the door
If you find the car you have your heart set on but as soon as you take it for a spin it doesn’t feel right, it is important to trust your instincts. Even if it is the exact model you are after and at the right price, if it feels like a lemon it most likely is. Have the confidence to move on and say: “no thank you”. Be honest with your appraisal and go with your gut.
Make a checklist
This list will be quite extensive if you are not certain what car you want. Your list should include important factors like fuel economy, space, comfort and safety rating. To narrow things down further, include factors such as interior and exterior wear and tear, braking performance, tyre condition, service history, stereo quality and whatever else you value in a car.
Now set a benchmark
With your checklist you’ll be able to compare vehicles easier. Scrap from your list any cars that you doubt and have a column to write notes of your observations after your test drive, like: “slight vibration in steering column when driving at speed,” or, “clunk in the front wheel when turning left”.
Pre-drive test
Before you even start the car there are several things to look for: run your eye along either side of the car looking for any imperfections or odd lumps, then look inside for the same. If there are any bumps, lumps or colours inside the door panels that do not match with the outside, this should sound alarm bells that the car has been repainted and was most likely in a previous crash.
Under the bonnet
Pop the bonnet and check the fluid levels and cleanliness of water and oil. Both should be sitting just under full when the car is cold. Look for any excess oil that has been splashed around, as well as any obvious fluid leaks , worn hoses or belts (i.e. perished rubber).
Tyre check
Drop the bonnet and run your eyes south to the tyres; they can tell you a lot. If they are bald you will obviously have to replace them but it is also a sign of laziness or potentially poor finances with the previous owner, which could be of concern when considering the car’s maintenance record. If the tyre’s wear is uneven, you can presume worn suspension parts, another cost to figure in.
Start it up
It is now time to start the engine. Give it a decent rev and make sure you look out for any signs of smoke coming out of the tailpipe- it is not ideal. Also listen for any strain to start and any clunking or undue rattles.
Get out on the road
If the car has passed the test so far, it is time to take it on the road. You’ll want to encounter a roundabout or winding stretch of road where you can accelerate hard after negotiating tight corners. When you accelerate hard, listen for engine strain and watch for smoke in the rearview mirror as neither of these are good signs. With corners, listen out for clunks and rattles which could indicate worn joints. Do some smoother turns to feel for flat spots or odd sensations in the steering as this is another warning sign. Find a smooth spot where you can brake hard; if the car doesn’t veer to either side nor shudder, you are in luck.
Check the extras
If all this checks out well you may be on to a winner. Finally you will want to test all the extras. Fire up the stereo, the electric windows and all of the other car’s bells and whistles. Make sure everything is fully operative as even the simplest faults may require expensive repairs. Also ensure there is no outstanding finance on the vehicle and that it is registered. If you are still not 100 per cent sure about the car, then get a second opinion. A professional evaluation can be worth its weight in gold if you’ve missed something and will generally only set you back under $200. Happy hunting.
This information was brought to you by YAHOO .
Non
Wow thanx guys and just as i was about to get 1 i am now enlightened about how the car is.But for me being a 20years old who lives in technology,i hope it wont be complex for me or i risk getting a w210.
'99 S420 125K
Thanks For The Buying Tips!
Having driven and learned about the "modern" MB vehicles of the 90's thru my 2 year ownership of a W124, a '94 E320, I've made the leap from the fryin' pan into the fire with my recent purchase of a W140, the '99 S420.
I must say the info here in the W140 forum was very helpful in understanding the intricacies of such a purchase, and quite encouraging. I'm anxious to study every nut and bolt on these marvelous vehicles, and I hope to contribute to the forum to the best of my abilities.
Land vehicle Vehicle Car Luxury vehicle Mercedes-benz
· W140 Moderator
Discussion Starter · #152 ·
Just a good read from W140 owners that review there experience .:thumbsup:
Kelley Blue Book
JUST ONE OF EM>:
A very fuel-economic war tank (irony)
By JJ on Monday, October 12, 2015
I own this car - My approximate mileage is 51,500
overall rating 10 of 10
rating details
Pros: "Built like a tank and built like no other car"
Cons: "fuel consumption if you drive it like it is stolen"
Likely to recommend this car? (1-10): 10
"This is a fuel-thirsty car (100 Litters or 25 gallons) but if you take in consideration that it is built like a war tank, then it becomes not-so-thirsty. Also consider the cost of every limb on your body, put a price on it and decide if it is better to pay the price in fuel which is far more economic. Again, built like a tank, nothing like it. Having 2 of them and having worked as accident-reconstruction investigator, I would never risk my life or any of my family's in a car that crushes to the point of being unrecognizable. How you drive this tank decides how it will consume fuel. Drive it responsibly without any sudden accelerations and it will be kind of economic. Drive it like a sports car and it will consume fuel like a sports car. Also keep in mind that until 1996 these cars are second-gear start. If you want to start in first gear you must manually take the shifter to "B" and then to drive - it will start in first gear for this time (repeat as needed). After 1997 keep the W/S switch in "S" or summer for every-time first-gear start. W stands for winter and would start in 2nd gear to avoid any slippery situation over the snow."
· W140 Moderator
Discussion Starter · #154 ·
300E / GLK350 / E550 / S600 / CLS550
I am thinking about selling my 1995 S-600 Coupe, depending
on the level of interest. It's a pretty car with some extra
features added. I also have 3 sets of wheels: original, AMG,
and the Mille Miglias shown. I've owned the car for 13 years
and she is very well maintained. What do you think? Please
PM or just respond here.
· W140 Moderator
Discussion Starter · #156 · (Edited)
Post #4 on the 1st Page received an interesting Buyers Update ,it was written by Member Ricko101 in 03-03-2008.:thumbsup::wink
Used Car Test Drive - 1992 Mercedes Benz 300SEL (W140)
http://chaosoftheroad.blogspot.com.au/2012/11/used-car-test-drive-1992-mercedes-benz.html
Buyers Guide .
http://australiancar.reviews/reviews.php#!content=guide&make=Mercedes-Benz&model=S-Class&gen=1247
Australian W140 Recalls .
http://australiancar.reviews/reviews.php#!content=recalls&make=Mercedes-Benz&model=S-Class&gen=1247
· W140 Moderator
Discussion Starter · #159 ·
