SL500
Hi,
I have a 94 SL500 with dead radio. The radio setup is with Bose and CD changer. The radio is a CM 2149 003-820-41-86.
Dose anyone know if a CM 2294 003-820-51-86 from a 99 SL will work in my car? The faceplates are identical, but I don't know if it's interchangable.
If no one knows the exact answer, can you point me in the right direction to research the issue.
Thanks,
George
CLK55/G500/E55/ML55/etc.
It will probably work, but not sure. It's easy enough to plug in and find out!
HOWEVER...
HOWEVER... to find more information, you can ask your dealer and ask for the price on part # 003 820 41 86. Then when he gets the price, ask him if it has been replaced by another part number. There should be a trail of "REPLACED BY" parts to follow, and if the other radio is in that trail, you should be OK.
Hope that helps.
-s-
