1 - 18 of 18 Posts
R.I.P. Never Forgotten
1983-2007 MB's
Yes, YOU can do it!
I have observed a lot of photodocumentaries done by this fellow member for our hobby and thought a good idea to consolidate them here for easy reference for our members.
Kudos to Mike (mclare) for all his hard work and sweat for our hobby!
I am sure there are a few more - will add them as referenced.
Photo documentary of Mike's 1991 560 build - Mikes_91_560_SEC
560 10:1 euro motor conversion, ASR Excision (a must read!) - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1542676-trek-up-north-holy-euro-motor.html
Hard brakes - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1430316-hard-brakes-possible-fix.html
Making your own "French" fog lights - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1424580-how-make-your-own-french-fog.html
Tying into the car's electrics - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1553496-x30-power-block-diagram-how-tie.html
SEC Door Handle removal - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1475606-sec-door-handle-removal-disassembly-reassembly.html
w126 Glass Sunroof Retrofit - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1654573-metal-glass-sunroof-conversion-diy-gen.html
Keyless entry in a w126 - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1638499-w126-keyless-entry-installation-made-easy.html
A/C Center Vents not working - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1459361-c-center-vents-not-working-fixed.html
Hirschmann Antenna Rebuild - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1432845-hirschmann-antenna-rebuild-control-change.html
w126 Colors in a Paint Can? Yes! - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1587436-does-anybody-know-if-you-can.html
Gen2 (86-91) MB Electrical Troubleshooting Manual - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1423605-gen-ii-mb-electrical-troubleshooting-manual.html
Water Pump R&R and Vacuum System Restoration - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1446652-c126-w126-water-pump-r-r.html
Brake Caliper Powdercoating and Rebuild - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1465942-how-powder-coat-rebuild-your-brake.html
Recaro Seat/Switch Restoration - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1499147-recaros-have-landed-another-restoration-thread.html
AMG Gen2 bumper conversion - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1500877-amg-body-kit-euro-bumper-conversion.html
Testing ABS Wheel Sensors - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1425313-abs-sensor-test-results.html
Hard Start Issue - Fuel Regulator fix - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1459751-hard-start-problem-solved-r-r.html
Rear Differential R&R - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1477950-inside-differential-rebuild-r-r-diy.html
Running Hub-Centric Spacers - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1479891-why-you-want-hub-centric-spacers.html
Shuddering while Acceleration - Rear Axle R&R - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1470874-shudder-upon-acceleration-high-speed-vibration.html
Dash Wood Replacement - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1468272-mclare-replaces-dash-wood.html
Gen 1 Pentas on a Gen 2 car? You bet! - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1465502-i-think-we-can-put-gen.html
ASR General Repair - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1428505-help-needed-repair-my-asr-system.html
A/C not blowing cold - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1457672-weird-c-issue-fixed-other-problem.html
W126 Instrument Gauge Face/Chrome Ring Installation - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1458095-diy-instrument-gauge-face-color-change.html
Rear Sunshade Installation - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1439118-got-my-rear-sunshade-today.html
AMG Steering Wheel install - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1440202-mclare-mounts-amg-steering-wheel-48hp.html
Cracking open a locked rolltop - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1440367-does-anybody-know-how-open-locked.html
Mounting AMG Trunk Spoiler - http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1433002-amg-trunk-spoiler-finally-mounted.html
2012 CL550 4MATIC Coupe
Wow! Thanks David! I didn't know I did all those threads! I am actually working on one right now as we speak.
If there are any pics missing from the threads, Post it in the thread and I will attempt to repair it. I have been working with the site administrator to restore the broken links and pics in my threads.
Thanks again! Hope it helps people.
1989 560SEL, 1979 Cressida MX32, 2006 F150 Lariat
YES mclare, it does help more than you realize. Thank you for all of the great DIY write up threads.
1990 560 SEL with Euro engine, 1998 SL500 Sport
Yes, YOU can do it!
That's quite the body of work! Thanks David for the compilation and of course Mclare.... that was quite the effort.
1988-300SEL 1989-300SE
amazing!! i needed the differential one with the pics!!! had it without them. gives me encouragement to install the diff on my latest benz i bought!! many thanks!!!!
1986 420SEL/1995 E300D/4 BMW’s/2 Vanagon’s
Awesome! I know when I did my water pump I used your DIY without the pics. It was still good.
1988 560SEC, 1987 420SEL, 1986 500SE
For he's a jolly good fellow...
Thank you, Mike, for your inspiration and help to many, and certainly myself. Great job!!
Sent from my Autoguide iPhone app
1985 300SD 1988 560SEC 822 1976 450SEL 1981 300SD
Many thanks...
..to you both, cornerstones of this forum imho...and nice guys into the bargain.
May your timing chain guides never crumble, and your AC blow ice-cold in perpetuity :)
1997 SL500 40th Aniversary 1998 C230 2002 E430 sport 1987 420SEL sold 1989 300E sold
Thank you Mike, for all the hard work, and then still being able to find the time to post it on the forum, that can take as long as some of the jobs themselves.
And thank you David for putting all of the links together, I'm sure endless amount of members are going to be using them over and over.
1985 500sel and 500sec 2012 E63 1989 Porsche 911
sticky this please
1989 560SEC
I tried to find a "Super Dewar" image but couldn't find one. This will have to do. Mike, thank you for all that you have given to the board :bowdown:
Mike
1983-2007 MB's
Discussion Starter #17
Thanks for the necro nirvana of re-upping your DIY's with photos today. This thread had collected your DIY articles into one TOC table of contents page.
Brings me back.... thanks Mike! :thumbsup:!
Thanks David!
1 - 18 of 18 Posts
