1 - 20 of 37 Posts
300GD 5 dr 1987, W126 420SE, W126 560SE
Does anyone know if I can fit the newer shape steering wheel from the late126s that has the airbag in it (Although I am not adding airbag just the wheel) to my 420SE? Is it a straight swap?
Its just that I like the later look?
Thank you
'84 500 SEC Euro 040 black Lorinser 2005 sl500
It will bolt right on no problem. The horn ring should also line right up (that would be your main concern to make sure the horn contact ring on the bottom of the wheel lines up with the electrical contact on the column).
Even many late model steering wheels will physically bolt right on but the electrical connections will need a little bit of customizing.
1981 300 SD, 1991 Geo Metro 4-door Automatic
On a related note...has anyone had any experience with smaller diameter aftermarket steering wheels? Success stories or epic failures?
Kodiakj2; I love how that newer wheel looks on the car. Could you let me know which model that is from (and the part no if you have it), and where you got it from. It would be a great help as the one thing that bugs me about the 126 is the truck steering wheel.
Also since my wheel's leather is all torn I need to replace it anyways.
Any help would be appreciated.
Thanks again.
2012 CL550 4MATIC Coupe
I have an AMG MoMo wheel that is smaller and I love it!
SuperModerator
1986/1990 W126
Smaller ones make a big difference to the cars feel. I have a Lorinser one thats a bit smaller than stock, the car feels very different because of it. But as somebody pointed out, the large wheel is designed partly for long distance cruising because its big enough that you can rest your arm on the door arm rest while holding the wheel.
1983 300 SD, 1991 420 SEL, 1979 300SD
so will a steering wheel from a W202 or W124 fit a W126 without major modification?
W201, W212, W221, & W222 Moderator
'84 Euro 500SE, '85 Euro 2.3-16, '51 Euro 170S, '97 Jeep Wrangler Sport, '15 G63 AMG
I thought about going for a smaller steering wheel at some point. But honestly, I've fallen completely in love with the massive captain's wheel used to steer my road yacht!! Yes, I'll admit it, I love pretending I'm the captain of a large land-yacht charting the unknown (but in reality known, :p ) streets around this town. I'm missing a captain's hat though...
Thanks again.
The wheel in the picture of my interior is from a 2000 s500 in black leather and Eucalyptus wood. Mercedes W220 S55 S430 S500 S600 STEERING BLACK LEATHER WOOD LEATHER AIRBAG on eBay!
Same wheel was used for the Maybach but they used more stitching on the leather and put wood control buttons on it. It will take some rewiring to get the horn working and the need to transfer the wheel clock over.
This picture below is of the wheel in a s500:
87 Euro500HVSEC. 88 Euro 560HVSEC. 89 Euro 560HVSEL
1988 Mercedes 500 sec
Anyone else fitted a w220 steering into a w126 is it easy to do and how does the car feel with it as its a 390mm as oppose to the original w126 which is 415mm
1991 560 SEC 1994 E500 2014 E350 Cab
Of course, just about anyone who could, did. I have two MOMO wheels and swap them every 6 months or so....because I can!
Too many to list
The w220/w215 wheels are cheap and look great
Finding a good w124 wheel (and especially one with wood ) could cost 10 times as much
1985 500sel and 500sec 2012 E63 1989 Porsche 911
got a nardi in the sec.... i like it
39
i also have the m40 version of the gen 2 amg
1988 300SEL W126
i changed mine with with C class steering wheel, i found a 31K miles at the junk yard, i bought it so cheap even without knowing if it gonna fit or not, and it didn't :grin, so i swapped the inside cores with the old one and the horn/airbag ring. and it worked perfectly fine.
1 - 20 of 37 Posts
