1983 300SD
Hi,
Does any one have a service manual that shows how to replace the left rear window run? If so, can you please post it here?
Also, I had a question about the transmission cable, the cable that comes from the transmission to the top of the valve cover. I noticed that the plastic adjuster on the cable is broken, so will that cause the transmission to not shift properly (like hard shifts between each gear)?
Thanks.
1983 300SD
Discussion Starter #2
I'm guessing that nobody has information on how to change the window run for the left rear window.
