Hi,
I own a w126 with that is pushing 600hp at the wheels and im having a issue while im on boost the rear end keeps squating until i let go. Car has steel lower control arms.
I originally had eibach lowering springs with b8 shocks, the squat was so bad it pulled my drivshafts apart and camber went nuts.
Then i replaced the rear springs with pedders 15kg springs with existing shocks it has improved like 70% but the squat is still there when your up on high boost.
How can i recrify the situation can anyone help???
Is my problem in my shocks now?
Is there stronger shocks than the b8 that i cant seem to find anywhere or is a revalve on compression my only solution?
Thanks you
Thanks you
