85 300 SD with 175k , 84 300 SD with 153k, 2004 Ford F250 Superduty, 2002 Volvo V70
Hey to all. I have done the proper searches in regards to the w126 300SD 85 model Steering Wheel and will keep trying. Can anyone poin tme to the proper place to learn about removing the steering wheel?
J:thumbsup:
too many
I assume you have the non-airbag version? If so, you will need to remove the center star/cap and get to the bolt underneath, I think its an allen 10mm maybe (search archives for right size). You will need to undo that and then slide the steering wheel off. It may help to have a helper and a long breaker bar as those bolts are in there very, very tight.
Ive never seen a 300SD 85 with Air Bags? The center piece is a nothing but a horn?
