1 - 9 of 9 Posts
Hey guys, not an electrical guy by any means, more mechanical.
How do I test the rear wiper motor? The connector on the en dof it It has 5 pins. Right side row of pins as you read from top down is 2, 4, 6. Left Side is 1 and 5, and 5 is empty.
I think the colors are green, blue, yellow, black, brown.
Do you know what pins I can put 12v to and which one to put a ground to to see how it reacts? I don't want to just be guessing.
Interesting question....in the two TE's I've owned, I've never had a rear wiper failure or reason to diagnose. Must be pretty durable. I don't know if they have 12 volts back there continuously and then switched to work the wiper or 12 volts sent back when you select the rear wiper. Also, it you go into reverse with the front wiper on, the rear is supposed to go on as well. Maybe you could wrap little solder pigtails to ea pin and plug them in, test with voltmeter etc.
Or just wait for one of the electrical gurus to see your query and they'll read the schematic. What problems are you having, that might be helpful?
Kevin
Basically I hit the switch on the dash, and the relay clicks back there, but no wiper movement. Another relay did the same thing too. I just wanted to jump it to see if I could see if its the motor, as obviously the switch works and the relay clicks.
Gotcha.......like I said, no rear wiper failure on two TE's, so I can't really advise other than to take the carpet piece off and dig in.
Did the wiper ever slow down or do anything unusual before it quit?
Kevin
Thanks for the diagram but I don't know how to read electrical diagrams :(
I was just curious what pin(s) to put 12 volt to with the motor unhooked from its harness by itself to see if it whirrs.
Motor M6/4 (rear wiper motor) pin 3 is ground, and I believe pin 4 is power to run the motor, pin 1 is powered as long as the car is on, so the motor will return to 'home'
Thanks, no response whatsoever from the motor putting a battery directly to those pins.
A replacement Ebay one that arrived like 4 days sooner than I thought worked just fine, therefore the old motor was just dead.
Good this got resolved. The rear wiper motor is very durable......I've seen little in the threads here over the yrs about them. But like any DC motor, they can fail.
Kevin
1 - 9 of 9 Posts
About this Discussion
3 Participants
Real1shepherd
Mercedes-Benz Forum
Full Forum Listing
