1 - 9 of 9 Posts
1983 300SD, 1986 560SEL, 1992 300D, 1995 E320 Wagon
Hey guys, are the sunroof motors interchangeable between post facelift and pre-facelift cars?
96 E320
You can look up the parts for different model years here:
But you will need to know the chassis/body code (can get it from your datacard). I didn't know that E 300's had two two different sunroof (or "sliding roof") motor types (electric and geared), for example. So you would have to know which one you have in that case (in addition to what newer model years have).
1990 Benz 300E 2.6 (mine) ; 1994 E320 Wagon (wife's) ; 1993 300CE Cabrio, needs some TLC
ok, lets see, for our 1994 E320 wagon, the motor is A1247800307
that PN is good for 124,079, .080, 081, 082, 083, 088, 090, 091, 092, 180, 185, 186, 188, 190, 191, 193, 290, 293
thinking those are all wagons... IIRC, 090 is 300TE, while 092 is 320TE/E320 wagon.
for my 1990 300E2.6 sedan, its A1247800007
that PN is good for 124.019, .020, .021, .022, .023, .026, .027, .028, 029, 030, 031, 032, 034, 036, 120, 125, 127, 128. 129. 130, 131, 133, 226, 230, 330, 333 (geez, never even knew there were so many 124's!)
those are probably all sedans.
not seeing the coupes there, so I'm guessing they have a different motor.
I know my VIN, but how do I know what my 3 digits after the decimal are? (i.e.: 124.xxx)?
Orrrrrrrr..wait, I asked too soon, I found it on Wiki:
Chassis codeYearsModelEngineBody style
124.0191993–1994200 E2.0 L M111.940 I4Sedan/Saloon
1994–1996E 200
124.0201984–19922002.0 L M102.922 I4Sedan/Saloon
124.0211984–1992200 E2.0 L M102.963 I4Sedan/Saloon
124.0221993–1994220 E2.2 L M111.960 I4Sedan/Saloon
1994–1996E 220
124.0231984–1992230 E2.3 L M102.982 I4Sedan/Saloon
124.0261987–1990260 E2.6 L M103.940 I6Sedan/Saloon
1990–1992300 E 2.6
124.0281993–1994280 E, 300 E 2.82.8 L M104.942 I6Sedan/Saloon
1994–1996E 280
124.0301986–1992300 E3.0 L M103.983 I6Sedan/Saloon
124.0311990–1993300 E-243.0 L M104.980 I6Sedan/Saloon
124.0321993–1994300 E, 320 E3.2 L M104.992 I6Sedan/Saloon
1994–1996E 320
124.0341992–1993400 E4.2 L M119.975 V8Sedan/Saloon
1994–1996E 420
124.0361991–93500 E5.0 L M119.974 V8Sedan/Saloon
1994E 500
124.036 (option 957)1993–1994E 60 AMG6.0 L M119 E60 V8Sedan/Saloon
124.1201986–1989200 D2.0 L OM601.912 Diesel I4Sedan/Saloon
124.1251986–1989250 D2.5 L OM602.912 Diesel I5Sedan/Saloon
124.1261993–1996E 250 Diesel2.5 L OM605.911 Diesel I5Sedan/Saloon
124.1281990–1993250 D Turbo, 300 D 2.5 Turbo2.5 L OM602.962 Turbo Diesel I5Sedan/Saloon
124.1301986–1993300 D3.0 L OM603.912 Diesel I6Sedan/Saloon
124.1311994–1996E 300 Diesel3.0 L OM606.910 Diesel I6Sedan/Saloon
124.1331987–1993300 D Turbo3.0 L OM603.960 Turbo Diesel I6Sedan/Saloon
124.2261986–1993260 E, 300 E 2.6 4Matic2.6 L M103.943 I6Sedan/Saloon
124.2301986–1993300 E 4Matic3.0 L M103.985 I6Sedan/Saloon
124.3301986–1993300 D 4Matic3.0 L OM603.913 I6Sedan/Saloon
124.3331987–1993300 D Turbo 4Matic3.0 L OM603.963 I6Sedan/Saloon
124.0401992–1993200 CE-162.0 L M111.940 I4Coupé
1993–1996E 200
124.0421993–1994220 CE2.2 L M111.960 I4Coupé
1994–1996E 220
124.0431984–1992230 CE2.3 L M102.982 I4Coupé
124.0501988–1989300 CE3.0 L M103.983 I6Coupé
124.0511990–1993300 CE-243.0 L M104.980 I6Coupé
124.0521993–1994300 CE, 320 CE3.2 L M104.992 I6Coupé
1994–1996E 320
124.0601993–1994200 CE2.0 L M111.940 I4Cabriolet
1994–1996E 200
124.0611990–1993300 CE-243.0 L M104.980 I6Cabriolet
124.0621993–1994220 CE2.2 L M111.960 I4Cabriolet
1994–1996E 220
124.0661993–1994300 CE, 320 CE3.2 L M104.992 I6Cabriolet
1994–1996E 320
124.0791993–94200 TE2.0 L M111.940 I4Estate
1994–1996E 200
124.0801985–1993200 T2.0 L M102.922 I4Estate
124.0811986–1993200 TE2.0 L M102.963 I4Estate
124.0821993–1996E 2202.2 L M111.960 I4Estate
124.0831985–1992 [14][15]230 TE2.3 L M102.982 I4Estate
124.0881993–1994280 TE, 300 TE 2.82.8 L M104.942 I6Estate
1994–1996E 280
124.0901988–1991300 TE3.0 L M103.983 I6Estate
124.0911989–1992300 TE-243.0 L M104.980 I6Estate
124.2901986–1993300 TE 4Matic3.0 L M103.985 I6Estate
124.0921993–1994300 TE, 320 TE3.2 L M104.992 I6Estate
1994–1996E 320
124.1801986–1989200 TD2.0 L OM601.912 Diesel I4Estate
124.1851986–1989250 TD2.5 L OM602.912 Diesel I5Estate
124.3931986–1993300 TD Turbo 4Matic3.0 L OM603.963 I6Estate
they are also embedded in the VIN, in the US vin, right after WDBEA, the two digits are the last 2 digits of the model number. the international VIN has the whole 124xxx near the beginning.
its also stamped on the plate under the hood on the radiator bridge.
In the interest of completeness...
Coupe 124.050 uses sunroof motor A1247800707
that PN is valid for 124.040, .041, 042, 043, 050, 051, 052, which is, I believe, all the 124 Coupes.
so, bottom line. face lift doesn't matter, but body style does, sedan vs coupe vs wagon....
I also just pulled a wagon motor and a sedan motor from junkyards. They are identical except for the black bracket that holds it to the car. So for those guys out there who can't find wagons in junkyards or wagon motors on ebay, just get a sedan motor and transfer your sunroof bracket over.
Sedan PN (in my example) was 1247800407, and the Wagon PN was 1247800507.
1 - 9 of 9 Posts
