You can buy the clutch/whatever to turn your diff into a LSD from your local dealership...I'm told.
Hmm, that's $1100 retail. Or $900 for me...Cripes, I think having an LSD is going to be an expensive affair. It's an option though! 30% is still better than none.1992 300CE comes with a 3.06 diff ratio. You can buy the ASD LSD carrier from Mercedes and install it into your diff, part number is 126-350-40-23, but the diff will have only a 30% lock-up.
That won't work without some custom work because the 190E 16v and 300D both use a 185mm size diff. Whereas all M104 engined car use a 210mm size diff.You've got a few options, but each has issues.
The LSD unit from a 190E 16v will fit, but has a 3:27 R&P
The ASD unit from a 300D 2.5 will fit and has the aforementioned 30% lock up, but it also has a 2:65 R&P. It more than likely needs to have the friction discs replaced by now, if you want even that amount of lock up.
A Phantom Grip-type of spider gear spring block (see the Kleeman link above) should be able to provide some percentage of lock up. These could potentially be used in conjunction with the ASD diff for a really aggressive setup.
Really, we need for gsxr to chime in here and give us the straight dope, since he's actually accomplished this goal via a modified ASD unit.
Not 100% sure, but possibly.Will the 190E LSD bolt in without a custom driveshaft?
It need only for ASD, not LSD.AND you'd also have to run the hydraulic lines and install the tandem pump, hydraulic tank, etc. to drive the diff.
If you set up the suspension of a W124 by starting with the individual wheel load and adjust spring rates with spring pads to get the proper weight distribution and transfer, there is no problem "launching" with much more than stock power and an open 3.07 diff..Look to Europe.. Lots of w124's with 4 cylinder engines had LSD without ASD.
Go over to the Uk boards for English, but actually mainland Europe is where you will find.
Non ASD to ASD swap is a lot of work, but for an LSD I thinks its worth it, it changes a lot about the way the car handles and launches..
Got some hints on this Obi Wan?If you set up the suspension of a W124 by starting with the individual wheel load and adjust spring rates with spring pads to get the proper weight distribution and transfer, there is no problem "launching" with much more than stock power and an open 3.07 diff..
Not an anomaly, it launches this way every time from a 1500 RPM torque load...
Goes for about six+ car lengths, chirps on the 1-2 shift and settles down...
Same rules apply be it for a drag car or track car right on down to a street vehicle.Got some hints on this Obi Wan?
