1 - 1 of 1 Posts
1992 300D -- 245K
Hi,
I am new to the forum. Here is my problem:
I have a 92 300D (225K) and the passenger side low beam is not working. The high beam works and I have swapped the bulb with the driver side to make sure that it is not the bulb.
I have replaced the fuses and checked the connections.
I then did a voltage test and the the lead the controls the low beam always measures 0 volts, it should be 12 volts.
I tried replacing the Hela module (126 542 01 32) and the did not do change anything.
Does anybody have the wiring diagram for the head light circuit?
Any other suggestions?
Thanks,
Mike Sheehan
1 - 1 of 1 Posts
