After some pointers, Started my 230te today, (hasnt been run for some time), it fired first turn of the key, when I touched the throttle, it cut out and now wont start. It has no spark
Have tried the following:
Checked, removed the ovp relay all ok
Fuel pump priming ok
Took king lead off coil earthed it, no spark
Coil reading 13.4v on pos -.15 on neg on ignition live, but replaced it anyway
Still no spark
Trying to recall on the early edis it does need a signal from CPS, next question is are they prone to failure, how to test and where are they.
Also if anyone knows if no spark is a common problem caused by something else.
The number 4 hammer will be coming out soon.....
Still no spark
