1 - 1 of 1 Posts
W124 E220 cabriolet 1993
Hi, I am getting close to finishing the E220 Cabriolet project however I have come to an issue with the selector box.
I used the working gearbox out of the doner car. However reverse is in the middle between P and R I don't need to use the accelerator for the car to move and it changes gear by itself due to the high revs. It revs very high when I put it into reverse. So what should be reverse "R" isn't - it's neatural instead.
Could this be the selector box? As I didn't use the selector from the doner car however they're both 4 speed selector boxes.
Any other suggestions? I'm sure there is adjustment on the connecting bar to three gear shifter?
Thank you in advance
Raj
1 - 1 of 1 Posts
