Always Remembered RIP
I'm thinking of buying either a 280SL or 300SL. Will the alloys I've got fitted to my '95 W124 E220 (Polished 8 holes 6.1/2 with 205/60x15) fit the '80s W107
BenzWorld Tire & Wheel God
wrong offset so they will not work...
Pity, are the last of the 300SLs ('88) the same as the earlier ones?
I'm asking as I mi...
I'm asking as I might be swaping cars and my E220 has brand new polished MB alloys (6.1/2Jx15 ET44)which as the dealer says doesn't affect the trade in values.
E430T + 300SL (W107)
Early (pre 86) 107: 6x14 or 6,5x13 ET 30mm
Late 107: 7x15 ET25mm
The problem with the ...
The problem with the late 107 is that the frontbrake callipers are so close to the rim. The original "Flush" has a very flat inner design, and many other wheels with correct offset (around 25mm) don't fit. As an example, W126 steel wheels don´t fit the 107 even though they share the same alu-wheels.
