my temperature gauge makes me crazy
when the engine is running the gauge shows 100-110
when i turn off the engine and back to acc shows 80-85
Does anybody know?
i cant find the problem
1995 e320ce. 1993 230 TE. 1987 Kit car with 260e running gear.
Voltage is higher when the engine is running.
Is your battery good?
Use a infrared temp gun to verify the real temp.
If the temp gun indicates around 90C then most likely your problem lies with the temp sender unit (your car has 3), the gauge, or the wiring in between
Also make sure your voltage regulator is not putting out more than 14.5V when the engine is running above 2000rpm
when i turn the lights on the gauge rise little on running engine you know
tells you that anything
i checked the wires from the riley to sensor from sensor tho dashboard no problem
That is not a proper diagnosis.
First you need to determine how hot your engine is actually running, hence the need to use a infrared temp gun.
Then determine how much volts your car is actually putting out. If it is overcharging, your car will behavior erratically and in some cases can even cause the battery to boil and explode.
yes sbaert
i fund the glow plug relay the power that is giving for the temperature sensor is 4.6 w when i start the engine is 3 w
i don know why is doing that and i dont know what is the correct w
