1997 w210 wagon E320 Avantgarde; 1986 BMW e28 528e; 1992 VW Golf Cabriolet; 1996 VW Transporter T4
Hi ! Can anyone help me come up with a real solution. My wagon started to ride like I was riding a horse... real bumpy, The immediate solution was (as anyone would recommend) to change/replace both accumulators. After having them removed, one of them was actually damaged... made evident by the fact that a screw driver will completely slide in into the hole (that's what my merc mechanic told me as a quick testing method for accumulators) . It then gave me all the reason to get new air cells. After fitting the car with new ones, it still had a hard and bouncy ride.
I would refuse to take the excuse that the new accumulators I bought (febi brand) are defective. What other tests can I do to check if the problem is because of other things ?? I was told to change the shocks but I am taking that option as my last resort for two reasons (1) they don't seem to be damaged as there are no signs of leaks whatsover, and (2) they're very expensive to consider right now and it may not really be the cause of my woes. I would like to check all possibilities before opening up my wallet.
The ultimate question right now is: Is it accurate to say that the only reason for a bumpy ride is a worn or damaged air cell and nothing else ? If that's the case, then can i conclude that I bought malfunctioning air cells.
If anyone among you had this sort of nightmare and solved it, PLEASE HELP !!! I terribly miss that benz ride like anything.
Les
Les
