I was just pulling out of my drive today and as I turned to the right the steering started juddering rather seriously, it soon went but later on it started again on full lock. Also if I'm stationary I can hear a whirring noise if I hold the wheel on full lock either to the left or right.
Does anyone have any idea what this might be? I hope it's not my power steering pump going out....
I recently had new wheels and tracking done, but that was almost a month ago and it was fine after that until now.
2001 Volvo V40
A whirring noise when holding the wheel on full lock is normal, the pump has to do a lot of work, that is also the reason why you should keep your wheel in full lock for a long period.
If it makes noise under other circumstances, first replace the oil and filter of the power steering pump. Those pumps are pretty bullet-proof.
W-1-2-3 Go!
Check the condition of the fluid in the power steering reservoir. Check also the tightness of the P/S belt. Could have been slipping.
When replacing the P/S fluid, drain the gear box as well. Holds around 1.5 to 2 quarts of ATF total, for gearbox and reservoir.
Sorry for the late reply, but cheers guys for your help and knowledge, I'd definitely replace the fluid and see to the belt
