1 - 1 of 1 Posts
1985 300D TURBO CALIFORNIA MODEL
Both sides stopped working suddenly. The driver side switch block is almost new. The other seems to function correctly. I carefully opened the older switch blocks, cleaned them thoroughly, made sure the contact surfaces weren’t corroded, removed slight patina with an Emory board, carefully reassembled them, tested them (mechanically....I’m a man without a meter...I know, one is on the way). The switches work fine, but no juice. How can they both fail at the same time, if that is the problem. Of course, I installed new fuses.
Please help!
1 - 1 of 1 Posts
