While doing some rust repair, I will need to remove rear torsion bar supports. It looks from pic (and car) that there should be rubber bushings, but on epc, I don't see any.
Can anyone help? Are they part of torsion bar?
The below site is for reasarch only. It has the part number and the different Mercedes Models that the part fits.
Stabilizer Bushing 201 326 10 81 MERCEDES BENZ
Autohausaz has this as an aftermarket part for $0.47 part number W0133-1807100
That is no doubt the part.
But what is confusing, is that EPC does not list that part as a 123 part. Even the link you provided does not include the 123.133 which is the designation for an 85 NA 300D.
Thanks for the research - I am sure that part is the one I will need.
Repair kit #8.
P/n A 123 320 0047
Thanks.
If that kit is still available, it looks like I would also need to buy part #11, the clamp part#1233260926.
I will check with my local dealer.
Checked with dealer today and that kit is no longer available. But the parts cab bought separately. Numbers are on epc except for rubber busings for which number is 20113261081.
Also seems that the reinforcing plate that the clamp bolts onto is available (on epc if you can find it!) Number is 1236100225. The otehr part that could be useful is the bracket that the rubber buffers on forward side of wheel well bolt onto.
