Good evening,
I need some advice. 1971 250C w/M130 engine and Zenith 35/40s. Rear carb idle air screw adjustment will not change mixture and can remove from carb and still no difference. I have rebuilt both carbs and front carb idle mixture adjustment works fine. I bought another carb and installed tonight. Same exact issue as before, idle mixture will not adjust. Both carbs are sync'd properly, vehicle has a "decent" idle and starts right up. Idle jets are open and clear. Can't figure why both carbs acts the same. 40 plus years working on cars and cut my teeth on carbs but I'm stumped.
