Hi everyone.
I'm new here, my name is Cam and I'm the proud owner of a clean W114 230.6
However just last week my engine developed a sinister high pitched and loud clatter under load. I'm not sure how best to describe it but it's really loud and sounds almost like a mix between a knocking and something spinning loose somewhere. It's very high pitched and noticeable (i.e everyone looks at you if you drive down the road).
The noise is also coupled with some smoke from the exhaust, but again only under load and when the noise occurs.
I've done a compression test and all cylinders are normal so I've started to strip the motor (beginning with removing the head). The timing chain is fine along with all the drive gear for it. Springs are a-okay as is all the other rocker gear and even valve seats.
So now I'm totally stumped and would love to hear your thoughts?
Cheers,
Cam
Cheers,
Cam
