1 - 12 of 12 Posts
1993 W140 300SE, 1969 W108 280SE
Hi guys,
I really need some expertise help here. My baby is a 1969 280SE W108 6cyl FI. After dropping and replacing the auto trans and coolant the car would not start. Before I did this she started first time every time.
I have cleaned the throttle and air filter/s 'tank' and noticed fuel leaking from the throttle?
I have tried addressing the problem with no luck
-cleaned throttle and air filters
-new s/plugs (has spark)
-new battery (due to hopeful constant cranking :S)
-new unleaded fuel
Any help would be greatly appreciated summers approaching fast :( :).
1996 W210 E320 ELEGANCE, 1972 W108 280SE 3.5, 1969 W108 280S, 1971 300SEL 3.5
Have you checked the fuel pump under the car?
When you firsat switch on the the ingnition, car you hear the pump buzz for a couple of seconds?
Where in Melbourne are you located?
1965 220S, 1999 Volvo V70 (wagon), 2006 Ford Crown Vic Police Interceptor, 72 350SL 4 Speed
Does the engine turn over and not start or not turn over at all?
GANSTA: Seen you around nice 'E' :) yeah the fuel pump is fine, brand new buzzes like a bee, i'm located in nth ringwood.
wbain: engine turns cranks fine, about to catch but will not.
Thanks for the complement on the E, I'm in Pascoe Vale South, other side of town to you.
I've had this happen to me before, check the condition of your cap and rotor if they look old, change them out.
When I bought my 280S, she started and ran ok, then the next morning it would not start, as soon as I replaced the cap and rotor she fired into life, I got the parts from my local Burson store, here are the Bosh part numbers that we worked out and I used......
Distributor Cap - GB75. My 280S is the caby version, might be the same, Double check.
Rotor - GB603
Contact set (points) - GB504, same as older Holdens and Valiants
Condencer - GB553
I only installed the cap and rotor because she started up, but I also replaced the spark plugs and the leads as they looked old.
Then acouple of weeks ago my 280SE 3.5 didn't want to start and all did was the cap and rotor and she started up like nothing had happened.
I hope this helps.
Cheers
Peter
Check your PM for my number if you want to give me a call.
Hi, hopefully you've gotten it started by now. I did have a similar situation with mine, (68 280se) and could not figure it out for the life of me. After checking backwards from battery connections, spark plugs starter motor, ignition, distributor cap and lines,...and everything being fine, I remembered I was reading something somewhere that said "not only do you need spark, but you need it at the right time." that's when I then remembered I was cleaning the interior of the distributor cap and had turned the rotor slightly. It's not common that it would be able to be turned manual by hand, but I went back and turned it a little to make the connection happen at a slightly different time then it was previously happening,...car turned over next time I turned the key.
I'm not a mechanic and I'm sure this is probably considered taboo, but it seemed like it that was the likely antidote, at least for my problem.
The distributor rotor under your distributor cap spins when you turn your key, it has a small terminal on the end that as it spins, it makes an individual connection with separate receiving terminals place around the inside of the distributor cap. These terminals are leads to the spark plug wires and eventually to the actual spark plugs. The spark needs to happen at the right time!
Good luck!! This is only for reference remember, consult with a mechanic before attempting anything.
Sent from my iPhone using AG Free
GANSTA: thanks for the advice, changed out the dizzy and rotor from Bursons..but with no luck :( .. this has really got me stumped.
Gross68: Thanks for the info I have noticed the rotor is in different places every time I open the dizzy will try and align it later today.
Super Moderator
85 Audi Coupe Quattro, 85 Audi Coupe GT, 71 BMW turbo 2002, 73 BMW 2002tii, 85 BMW 635csi
What's the voltage at the injectors while cranking? Neutral safety switch on transmission mis-wired :dunno:
Ohk i've narrowed it down to the rotor and distributor alignment and timing.
After playing with the dizzy, rotor and leads she wanted to start more than ever but did not and in the process killed my battery again *%^#!!
If there is any links/pictures or advice on alignment and the process this would be much appreciated.
1 - 12 of 12 Posts
