G
Guest
I'm looking for a trunk lock cylinder with key
(square) that will fit a 85 300D.
Need to getmy trunk open
1980 300sd, 1998 e320
it might be easier to open the trunk if your car uses an air pump to open the locks. I believe that it does. You would locate the air line going back to the trunk. This is a yellow line that should run next to the door jam on the back passenger side. you would either blow or suck the line to unlock the trunk. Then you could probably remove the lock barrel and get a key for it.
G
Guest
There is no lock cylinder in it now,
just the outer case that pushes in.
I try'd my Vac kit (suction) but did not try
the air pressure.
Still would like a cylinder and square key
