I have a 1992 400SE with an itermittent problem with the right side turn signal lights. When the car is warm or it is hot outside - the turn signal lights stay on - even with the indicator stalk inside in the center position - the only way to get the lights off is to disconnect the #17 fuse - the lights will not stay off until the car cools off - the Lighting control module has been replaced by the local dealer for almost $400 - their next fix will be to replace the multifunction stalk - Anyone have any other ideas? I live in FL where it is warm - the dealer has had the car three times in a month - and still can't fix.
