1 - 9 of 9 Posts
ML320 2002
ML55 2003, ML63 2007
You can't do any coding on MB with that, so you are buying just a scanner. It's much cheaper to get the Autel.
Did you give up on the SDS?
ML320 2002
After buying S3 and S4 that did not work, I gave up on SDS.
Vxdiag software is compatible with Mercedes but still under development status. Maybe they can enable coding soon. Firmware is upgradable.
ML320 2002
Discussion Starter · #8 ·
List of all the supported vehicles and protocols.
http://www.vxdiagshop.com/upload/service/vxdiag-multi-diagnostic-tool-with-original-software-intruduction.pdf
http://www.vxdiagshop.com/upload/service/vxdiag-multi-diagnostic-tool-user-manual-1.pdf
Compatible with Three Automotive Industry Standard
 SAE-J2534-1/2 Pass-Thru Driver with EURO 5
 ISO-22900-1/2 MVCI with D-PDU Driver
 RP-1210A/B/C Heavy Duty VDA Driver
J2534 OEM Level ECU Reprogramming Function
 ECU software update and calibration
 ECU replace flash and programming
1 - 9 of 9 Posts
