SLK 230
I've changed my headunit on my SLK awhile ago and when they were installing it they said that the new deck produces more power (2x) than the orginal benz deck. The effect is that volume will be loud when the volume is at around "4" when compared to "20" for normal. They mentioned this device that can fix this problem. During the time I did not opt for it due to costs, and now I might want to go that route. Does anyone know what this device is and is it easy to install?
TIA [:)]
2002 C230k
I believe what you need is a line output converter (LOC). If you have a Bose amp the co...
I believe what you need is a line output converter (LOC). If you have a Bose amp the correct one, according to info on another board is the Ven 4.5
http://peripheralelectronics.com/periph_products/line_output_convert.htm
