1 - 11 of 11 Posts
I've got an 84 300dt sedan that's cooking batteries.
It wasn't charging the battery or powering the headlights until I replaced the Voltage reg some 3 months ago with http://img.eautopartscatalog.com/hires/W01331623408BOS.JPG?width=300&height=300 which I thought was the right one.
Now it evaporates all of the water out of my battery ( Search: H8-DLG | Battery | AutoZone.com ), which replaced with steam distilled about every 2 weeks for the past month and a half.
The car has a mystery year motor/tranny in it, from a donor 300cdt, I'm wondering did the voltages/amp req's change midway through the run of the w123? do i have the wrong battery/voltage regulator?
Thanks in advance for your help; I don't know jack about electrical issues.
2001 Volvo V40
The regulator wasn't changed. Have you measured voltage with the engine running. It should not be above 14.4 V, but it probably is.
1984 300D
If you are in the US Harbor Freight Stores sell inexpensive Volt/Ohm Meters (Multimeter).
The meter is also useful to check Glow Plugs.
It could just be the New regulator is faulty.
99 SLK230 Kompressor, 5 Speed Manual
Yes, you definitely need to measure the voltage. I have used low cost VR's on these cars with great success, but I don't recognize either of those brands as being one of them.
Yeah I put the meter on it and it showed 14.0 volts at idle; who makes a better voltage reg than Bosch? Wasn't Bosch the OEM? I'm wondering now if the reg just isn't shutting off; continuously pumping juice whether the battery can take it or not.
This morning the car wouldn't even jump; but that could be related to the completely toasted battery wired in.
14Volts is not going to fry a battery. Even if it is fully charged and hammering 14Volts constantly, that should not fry it in short order. It will perhaps shorten the life, but I would not yet condemn that VR unless you have discovered something else that I did not pick up on when I read your post.
well it's putting out 14v at idle. I haven't checked while the engine's above idle. I took compress ignite's advice and ordered a new voltage reg from peachparts and we'll see if they fixed it. If you remember from my first post i had a pic of the one that i ordered; peachparts lists that as a 'round body late style' vs. the 'square body, early turbo style' that i ordered (and was what I found on the alternator when i started this mess).
I assumed that a voltage reg for a 300dt was ubiquitous, but it seems that peachparts atleast makes a distinction. I'll install it when i get it and report back.
I'm also on the way to pick up a new battery.
Final update, after some very trying parts sourcing from peachparts, I just bought a new alternator with internal voltage regulator installed. that and a new battery, and a few minutes to clean all of the connections and the car's been running like a champ.
1 - 11 of 11 Posts
