vito 111cdi 2008 cranks but wont start there is no air in lines low pressure fuel pump ok,There is 350bar at rail when cranking injectors checked ok back leak test ok,cam and crank sensor ok all other sensors checked ok. it sounds like it is going to start but it dont It does start with easy start but as soon as I stop spraying it stops.All glow plugs had gone also glow plug module wasnt good but they are all new now.The only code showing is (2263 Lin message from alternator ,faulty message or timeout permanent) All fuses in fuse box ok.Fuel pressure sensor on rail ok.
Discussion Starter #2
I dont kow if it makes any difference but the front of van is removed Ie headlights etc..
