Hi,
First post but I have had lots of help from the forum from other helpful threads.
My Vito 638 112 has had plenty of problems but usually rust or injectors.
Latest problem is that after a non start I have no windscreen washers, heater or speedometer and the abs ebv and traction control lights are on.
During the non start event I was getting nothing when the key was turned. I was poking around under the bonnet while my boy was working the starter on and off when suddenly the van started. Dash symbols have been on and no washers, heater or speedometer since.
I've been all round the dashboard, covers under the steering wheel and under the seat but not a single blown fuse or anything obvious I can see.
Hopefully someone has had this before and can shed some light on the problem.
Cheers
I had this problem with my w639 where I lost lights, indicators,horn,central locking etc anyway my sam unit had gone down.Replaced it with 2nd hand unit all fine.
I've had a dig around.
The only thing behind the fuse box that isn't just relays seems to be buried under the carpet under the handbrake lever.
I can't find any info online about what might be under there.
The airbag thing is under the handbrake, Ecu behind the dash heater vent closest to the window, all the relays under the seats and the three separate fuse boxes is all I'm seeing. Behind the fuse box under the steering wheel is a big black box with a couple of relays and inside lots of copper running everywhere. Apart from that I've no idea where else to look.
