Yep.
It's behind the dash on the right hand side. If you pop the air vent with a screwdriver (carefully!) you should be able to see it. Silver box about 20cm square by 10cm deep with 4 or 5 connectors plugged in the top.
The ECU for the immobiliser is behind the instrument cluster if you need that........
Yep.
I could only find the comfort ecu behind the dash. What am I missing?
