1 - 19 of 19 Posts
ML63 AMG & 2 350 SLK with AMG kit.
Lots of this very odd to use calliper paint later and there ready for the decals, they should arrive tomorrow, I had some curved AMG decals in black to go on.
Not a cheap set up but worth it to stop these rapid vans!
2006 Vito 109 compact.
My van is the 109 so doesn't really warrant anything like this...that doesn't stop me wanting them though! how much is that little lot going to cost?
Regards
Phil
W204 C320CDI 2009 and W639 Vito 115CDI 2006
I'd love to be able to lift the back wheels with some late braking into a roundabout.
When you say calipers from eBay I'm assuming used items from a breakers yard?
Yup. He means source the callipers however you want. If you flush with money you could always buy new callipers! So all in this upgrade would be around £400!
Vito 280 ,ZX7r,gsxr 750, ,Z650 Cafe ,Benelli Tornado.Ford consul , Ford Pop , ,Chevy Astro,Dog,Wife
Are there any issues over in the UK with 18/19/20" wheels with non-commercial tyres fitted at MOT time...I have to change my discs, calipers and wheels for our test...PITA if i'm honest as it means doing it in the depts of winter...:frown
No problem with tyres as I run 101 index on 20" extra load so more than covered.
Callipers used are around on ebay but are not cheap, around £300 each or more.
Pads again not cheap, genuine £200 a set.
Look for C63 SL55 amg etc and you will find them.
Ouch!!!
What other callipers would fit or what other Mercedes fit the same callipers?
Regards
Phil
Discussion Starter #13
Ouch!!!
Regards
Phil
Thats cheap, there a grand each new! nothing other will fit.
There are companies that make big brake kits all new and prices start from £1500 plus vat.
If you think thats bad have a look at what the VW guys spend on the T5.
Discussion Starter #16
Nice Ian. What about rear ones? Same from c63 etc or need to do some mod?
Rear is a bigger job but yes it will have to be done, the problem is the hand/foot brake, I need a cross ref of the rear disc and brake shoes for a start, it disc does not get much bigger but does become vented.
Hi i am in Australia and interested in upgrading brakes , would your kit be available to send over? i run 20" rims with 45 offset . you can email me directly if its easier . [email protected]
thanks for any help
regards
Andrew Gilmore
Hi, found this threat from a few years ago.
I want to upgrade my Vito 122cdi.
i can source C63 calipers
they talk about 360mm discs, from what model? Because the disc offset changes...
and I need those custom brackets! Who has them? Who makes them?
@Zenmann 63
1 - 19 of 19 Posts
