1 - 16 of 16 Posts
2008 vito 115 CDI dualiner
Hi all, Had my air-con regassed about 2 months ago, all good for a while , then the last two weeks, has heard a sort of low pitched whistling. like a coke bottle being opened when you turn the engine off. Now the air con does not seem to be cooling hardly at all. When it was regassed by ATS they said it had none in it at all. I was under the impression that they had to test the system to some degree before they regas incase of leaks. What do you reckon ? is it likeley they have refilled it incorrectly and its leaked out , or is it just one of those pureley co-incidental things . If i take it back to them to have look will they be able to diagnose the problem or should i get a specialist to sort it for me ??
Thanks for the advice
Nick
2013 vito 113, 2012 Vito Sport X
Nick had the same problem with ours, whistling sound from the centre dash area, nearly drove me mental until I discovered it was the aircon and it stopped if you turned it off, next day noise had disappeared along with any cooling, turned out to be the aircon condensor that had a hole in it, was still under warranty so unsure of cost, apparantly debris gets in behind the cover and wears things away, the fitter said the new ones had a redesigned cover to prevent the build up.
Mark
hopefully theyve put some UV dye in it and might be able to locate the leak. Sometimes when you gas an AC system you cannot directly locate a leak sometimes it takes a couple weeks to represent itself. Take it back to them and hopefully they can find it this time.
No not yet , was going to ring someone but been on hol for a few weeks.
Nick
ML63 AMG & 2 350 SLK with AMG kit.
Ok found 2 leaks
One on the dryer, seems to be a replaceable part in the condenser
And the top valve has some dye stains.
Dryer A639 835 06 00
Ring A 639 994 13 41
Vito 111 cdi
kind of same problem on my vito 111
Hi,
It's my first message on the forum :). I don't know if I should say ;) that but I'm french, sorry for any bad english.
My A/C is not working anymore, with quite same symptoms as above. I made 2 gas recharges, and some valves in the engine compatment were changed but it still won't work for more that 2 weeks after the charge.
On last gas refueling, and after 2 weeks, I still had some cold air on the passenger side but now it's over. The A/C specilalist I went to thinks that it's the condenser which is in fault.
Do you know how how this part can be visualy controlled (where is it?) and if it's true that to change it the whole dashboard (and even steering wheel bar) have to be removed ? My mecano announced me a 1000€ bill :/
Thank you for any help.
Bude
It will be the condenser.
This is the radiator in front of the cooling radiator, wide and thin, you need to strip the front to replace it, stones damage them.
Great care must be taken with the new condenser when refitting the cooling fans as this can cost another condenser!
Vito 111 cdi
Ok thank you for this fast answer!
is it here, behind the fans, the first radiator ?
If yes I don't understand why (well hmm...) my contact talked about unmouting all the dashboard and the steering system...
do you know some good reference for part buying, and unmounting/mounting instructions ?
Thanks again !
Yes thats it, Very common fault on these with stones hitting them.
The one in the heater should be sound.
It comes out with the bumper off and the front crash brace removed.
You will need new from MB, it comes with the dryer etc and must be re gasses as soon as its fitted.
Get it pressurised and get some soap bubbles on it and you should see the holes.
Vito 111 cdi
Thanks zenman
I realized that the A/C "expert" to whom I shown my van had talked about a possible evaporator failure... i will try next weekend to have a good view at the condenser, but I may not be able to put pressure in it so it would be a simple visual check. Otherwise I have the possibilty to pay someone so that he tries to find where is the problem.
Btw I found a nice tutorial for the condenser replacement (in french ;)) so i put the link here :http://www.forum-auto.com/marques/mercedes/sujet9625.htm
I will update the status of my problem here.
Seeya
Bude
Discussion Starter #14
Link is working fine now, wish i spoke /understood better french, google chrome helps a bit but could do better LoL
Good pictures though
Nick
For those who may want to follow (roughly) the guide from the kind Gents link above, I have done a reasonable translation with google and created a quick pdf using the original pics.
I may just be giving this a go myself soon.
If you don't want to downloadthe doc then the writing without the pics is below.
Hope this may come in useful for folk.
"Come on, I'm going into a tutorial to change the air conditioning condenser
-for info MB gave me a quote of € 706 for replacement not passing Os..o not to mention them, I got out for 148 € of pieces delivered in chronopost and 60 € air conditioning recharge in nortoto or € 500 in savings. Ps: it's better to be 2 especially for the output of the fan unit and the condenser because there is always something that hangs.
We start by removing the grille (the 3 black torx screws)
Then the bumper 4 torx screws in the front and 2 in the undertray behind the cover 2 below in addition to plastic clips for the skirt
Be careful not to tear the wires from the parktronic
Then we remove the headlights 4 screws of 10
Then we remove the airbox
After to have access to the condenser, we remove the fan unit (you have to play with the auto gearbox radiator when you have one)
And the 2 large build-ups of insects
There was surprise at unpacking, the new one is very bent, after a sandwich between 2 boards it looks better
To gain access to the condenser from above, you must unscrew the front berseau (it is useless to remove everything because there is a lot of things fixed on it)
2 screws on each side at the top then a horizontal screw on each side then 2 vertical screws on each side of the radiators there we just loosen them and watch out For the hoses which are very close it almost touches.
After scraping insects with a small screwdriver
This is what it gives the condenser removed
The 2 pipes that go to the condenser
The new condenser in place.
Voila, I'm missing some photos because in the heat of the action, well we don't always think about photos.
1 - 16 of 16 Posts
